DylanMadigan
I have a 4ft long GMRS antenna, it is within a pvc pipe. Right now I have both the tx and rx antennas on the barn, but i cant get them too high (theres no good place for guy wires, and i dont have much money or need a large coverage area). The issue is that while the tx antenna gives pretty good range, would like to increase the receive range for handheld radios.
So I am fairly new to all of this, and I've seen it done, but I've never done this myself. I think i can mount the mast to the tree using a few stainless steel bands (stainless mostly so i can adjust them over time so i don't just choke the tree), but this would make the antenna the highest point on the property by about 10ft, so now my concern becomes lightning. I'm thinking its a good idea to ground the steel mast (with an appropriate 8ft grounding pole in the ground), but is there something more i can do for the antenna it's self that wont hinder the signal more then having it 15ft lower? Its encased with PVC with a grounded steel mast under it, but im not sure that PVC will hold back the EMP given off by a bolt of lightning hitting it.
The two biggest reasons for the move to a tree is to increase the height, and get it further away from the tx antenna (this has caused some issues with our handhelds transmitting to it from town).
