Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 05-22-2016, 8:41 PM
radio3353's Avatar
Default Unication G4/G5 and P25 Phase II
Does the Unication G4 or G5 receive P25 Phase II? What is the cost (approximate is OK) for one unit of either model? Any suggested dealers who are willing to sell to the general public? Thanks.
Old 05-22-2016, 8:48 PM
There are two threads about the G4 and G5 in the all other scanners forum
All Other Scanner Manufacturers - The RadioReference.com Forums
Old 05-22-2016, 9:01 PM
radio3353's Avatar
Thank you. I will check them out. I think I need a road map to navigate the multitude of forums here.
Old 09-19-2016, 8:09 PM
Signal-Zero's Avatar
Simple answer...it does not currently receive TDMA talkgroups, but it will receive FDMA talkgroups on a Phase II system. Unication has indicated it will be releasing a Phase II firmware update for TDMA possibly by the end of this year.
"We celebrate our independence from the Government, not our dependence on it."
Old 04-05-2017, 10:33 PM
verhoffj1's Avatar
Default G4 Phase 2
[QUOTE=Signal-Zero;2643915]Simple answer...it does not currently receive TDMA talkgroups, but it will receive FDMA talkgroups on a Phase II system. Unication has indicated it will be releasing a Phase II firmware update for TDMA possibly by the end of this year.
Well here we are April 5th 2017 still no Phase 2!!! I Would by One immediately if it supported phase 2
Old 04-06-2017, 11:02 AM
Skypilot007's Avatar
[QUOTE=verhoffj1;2746132]
Yep....me too. Patiently waiting.
Old 04-06-2017, 1:56 PM
radio3353's Avatar
[QUOTE=Skypilot007;2746349]
Me three. It seems to take a long time for Unication to issue updates.
Old 04-06-2017, 6:55 PM
aaron315's Avatar
I'd prefer they take as long as they need to be sure it is as close to perfect as possible before releasing an update. We get enough shotgun firmware from the scanner manufacturers. Quality takes time.
I am responsible for what I say. I am not responsible for what you understand.
You're never on time for a disaster. If you weren't late then you didn't have a disaster; you had an inconvenience.
Old 04-10-2017, 12:29 AM
seth21w's Avatar
Unication needs a rep on this forum, i bet if they knew how many sells they could get if they did do tdma and had a rep on here like ww and up man. Lots of revenue to be had.
Uniden BCD436HP BCD536HP Whistler WS1098 Tytera MD390G RTL SDR
Old 04-10-2017, 12:33 AM
kma371's Avatar
Global DB Admin
they already do.
Unication_David RadioReference.com Member Profile
Old 04-10-2017, 9:59 AM
seth21w's Avatar
Originally Posted by kma371 View Post
Well he dont say much lol i am just wondering how the little pager is going to perform on p2 if its even capable vocoder wise.
Old 04-10-2017, 10:31 AM
tumegpc's Avatar
I know the G5 can record memos , what about P25 audio ?
If so is it per channel ?
TRX-1 ~ TRX-2
436HP ~ 536HP
Old 04-10-2017, 10:36 AM
tumegpc's Avatar
I'm thinking of giving the G5 a try due to the simulcast distortion in my county . Any recommendations? Any users with regrets to purchasing the G4/G5 ?
TRX-1 ~ TRX-2
436HP ~ 536HP
Old 04-10-2017, 2:15 PM
BenScan's Avatar
I like my G5 enough, after fighting with trying to get Uniden and Whistlers to work on the regional P25 system I monitor, that I bought a couple of G4s too.
I don't have any regrets, but there are things I would like to see improved, including adding Phase 2 and a more responsive user interface.
I wrote a review a while back. It's available at the link below.
Unication G5 Voice Pager as a Scanner - Review
Old 04-10-2017, 2:18 PM
sparklehorse's Avatar
I like mine. I use it every day while mobile, works good for that. Luckily my local system is still Phase I. I don't use it at home because frankly the audio isn't that great. It's kind of "hollow" sounding. Kind of tinny. It decodes P25 in a moving car better than my BCD436, but at home I prefer my BCD536 or TRX-2. Those will miss more transmissions, but overall they are more pleasant to listen to. Of course, I'm using Yagis at home, which are not an option in the car. I do wish Unication would throw us a firmware bone in the form of a Talkgroup hold function, talk group scan delay, and muting encrypted transmissions. Those functions are sorely missed, and would go very far toward improving the usefulness of these otherwise fine radios.
Unication G5, BCD536HP, BCD436HP, BCD325P2, DJ-X11T, DX-R8T, Satellit 800, FT-8800R, BCT15X, VX-6R, TG-UV2, UV-B5, BC250D, BC780XLT, Pro-2006 PAST: TRX-2, WS1065, AR8200Mk3, BCD996XT, BCD396XT
Old 04-10-2017, 4:57 PM
tumegpc's Avatar
Thank you guys for the info and review of the G4/G5 .
One more question, looks like you're limited to connecting an external antenna unless you purchase the base. Do you find that the sensitivity the same or better when comparing to the 436HP ?
TRX-1 ~ TRX-2
436HP ~ 536HP
Old 04-10-2017, 5:20 PM
Well the base is only good for the G5 where you can monitor VHF/UHF with an added external antenna. Otherwise VHF/UHF is monitored by a small internal antenna inside the unit. The 800mhz is what you can monitor through the external antenna SMA connector already on the unit. That can also be modified via adapters or a better SMA-F antenna. Just be careful not to damage that pin on the radio.
Old 04-11-2017, 12:19 AM
W8VI's Avatar
I am monitoring clearly with no drop outs five different 800 MHz P25 systems 10-30 miles away with a 7 inch antenna connected to the G4. Sitting next to the G4 monitoring the same systems is a 436HP that on a good day can hear about 15% of what the G4 is able to reliably monitor. With the 436/536 the more distant counties are nearly deaf compared to the G4.
Part of it is the excellent receiver that is designed for only 700-800 MHz but I believe the biggest difference is Unication has figured out the simulcast issue of selecting just one towers signal while ignoring the others.
For whats its worth I no longer use or need a 800 MHz yagi on two towers at 85 and 40 ft to monitor five local county systems. The stock and 7 inch antenna on the G4 works better monitoring the adjacent counties compared to any other receiving configuration I have tried.
When Unication finally updates to Phase II I would expect a similar LSM receiving advantage compared to current consumer scanners.
Unication G4, BCD536HP, BCD436HP, HP-2E, Airspy
Old 04-11-2017, 7:17 AM
tumegpc's Avatar
What brand 7 inch antenna are you using?
TRX-1 ~ TRX-2
436HP ~ 536HP
Old 04-11-2017, 11:44 AM
W8VI's Avatar
A Motorola Part # 8505241U11 is the 7 inch antenna
Also have a 3 and 3/4 inch Motorola Part # NAR6595A antenna
Here at my location the 7 inch normally receives 1 signal bar better and is less susceptible to modem and computer RFI. I use the NAR6595A while mobile or away from the shack on a second G4. The 7 inch antenna receives the distant 30+ mile systems better as expected.
Check out the Unication thread - Better G5 Antenna for some excellent opinions on G4/G5 antennas.
