Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #341 (permalink)
Old 02-21-2018, 3:26 PM
Originally Posted by radio3353 View Post
Speculation doesn't answer the question. It just fuels rumors.
Nice thing about having this forum is that anyone can simply go through and see Unication's past actions. I'm not trying to stir up anti-Unication sentiment but just voicing an opinion molded by months of lurking here. Maybe I'll be pleasantly surprised with an earlier release. Of course given the track record on buggy PPS releases, let Unication stretch out and take all of Q1. If it ships March 31st, it's still Q1...
I have a pre-order for one of the P2 G5's and have been trying to give these guys my money for well over a year. There is only one system in my area that I want to listen to. It's been 100% P2 from the beginning and extremely difficult to monitor with a scanner while mobile.
  #342 (permalink)
Old 03-29-2018, 12:13 PM
Default The Official Latest G4/G5 Firmware and PPS Thread
Q1 ends after tomorrow 3/31
Just wondering if the
phase 2 upgrade will come out soon.
Yes, there are stupid questions. Don't ask them.
  #343 (permalink)
Old 03-29-2018, 4:45 PM
au1344's Avatar
Check these threads for your answer
https://forums.radioreference.com/un...w-details.html
https://forums.radioreference.com/un...days-away.html
au1344
BCD436HP and Unication G4 Owner
APX 6000 and APX 6500 User
  #344 (permalink)
Old 03-29-2018, 4:47 PM
radio3353's Avatar
You really need to keep up.
  #345 (permalink)
Old 03-29-2018, 4:48 PM
[QUOTE=au1344;2907682]Check these threads for your answer
  #346 (permalink)
Old 03-29-2018, 5:48 PM
Drumbum's Avatar
From what I understand from a guy in town that sells them,,it has to be sent to the area rep , I was told that the last firmware had the upgrade in it just needs to be activated, he told me,first of April , will see
Sent from my VS995 using Tapatalk
  #347 (permalink)
Old 06-13-2018, 6:53 PM
Great radio, beats the hell out of my BCD996P2 on the TRWS (Mesa/Gilbert, AZ) P25 Phase I system. The simulcast was impossible to monitor, all garbled.
So this would be the perfect radio if:
1. You could pause on talkgroup
2. You could lockout a talkgroup
3. You could add a delay to a talkgroup
4. Had an external output jack
5. The belt clip locked onto the radio better
Are you listening Unication?
Thanks....
  #348 (permalink)
Old 06-13-2018, 8:29 PM
Turth there
Sent from my SM-N950U using Tapatalk
  #349 (permalink)
Old 06-13-2018, 8:30 PM
Thats the Truth there
  #350 (permalink)
Old 06-14-2018, 5:04 PM
Homeboys-Scanna's Avatar
I second that. The only things that's been stopping me from pulling the trigger is a lack of scan delay and no scan hold / resume button.
"Copy, 132 and Bush, cover's code 3."
  #351 (permalink)
Old 06-14-2018, 5:06 PM
Its ways around that and its still flawless
  #352 (permalink)
Old 06-14-2018, 5:08 PM
davidzimmerman's Avatar
i got my G5 last year and LOVE it BEST money ever spend also got the TRX-2 sold my Pro-197 for better and the TRX-2 works just as bad as the Pro-197 did.
  #353 (permalink)
Old 06-14-2018, 9:05 PM
eorange's Avatar
Belt clip locked onto the radio better?? Are we talking about the same belt clip? Removing the clip from my G4 was extremely difficult, so much that I hesitate putting it back on ever again.
√-1 2 π
  #354 (permalink)
Old 06-14-2018, 9:07 PM
Pull tab and slide up, easy as hell
  #355 (permalink)
Old 06-14-2018, 9:10 PM
Johnnydollar2's Avatar
Default official blah blah
etihparg must have meant "differently" instead of "better" I hope* IT was the most difficult thing I've had to try and remove since a bottle of plastic skin was shaken up and the cap was GLUED on to the top from the inside. I busted my knuckles getting that thing off and finally had to spray WD40 in the notch and pry it out with a small flat head screw driver. AFTER it finally gave, I put WD40 and vaseline in the notch and on the tab. It was almost as bad the 2nd time I had to put a battery in. It's finally more "manageable" now. I'd like to see it with 2 small screws holding a metal bar, just like the old PRO96 was. hou30guy should review the old posts about it after it first came out*
  #356 (permalink)
Old 06-14-2018, 9:21 PM
radio3353's Avatar
Bold emphasis mine
Not understanding this. They are not scanners. Do you mean TG delay and TG hold/resume? I agree they would be useful features. But, then again, I only listen to one system so not a deal breaker for me. For the system I listen to I assign different talk groups to different knob positions and switch when needed (which is not very often since, as a former firefighter, my interest is really just that realm.) For somebody listening to many talk groups at once then delay and hold features would be quite desirable and hopefully Unication will bless us with that someday.
  #357 (permalink)
Old 06-14-2018, 9:27 PM
radio3353's Avatar
For sure!! My belt clip never when back on once I got it off. I don't use it and I never want to have to take it off again.
  #358 (permalink)
Old 06-15-2018, 8:58 AM
eorange's Avatar
Ha, I was wondering the same thing. I thought for sure I'd snap something off. I finally punted and e-mailed Ray's Pagers, which is where I bought it. Ray responded right back and said to slide a coin under the tab and pry up, but not too much. That did it, but it was still a bear to remove.
√-1 2 π
  #359 (permalink)
Old 06-15-2018, 1:00 PM
The belt clip WAS a bear to remove the first time. Possibly I did not have it properly re-attached. Have to look at that. UPDATE: Make sure it is locked into position. I had to puh the tab in until I heard the click. Okay now.
  #360 (permalink)
Old 06-16-2018, 8:11 AM
troymail's Avatar
I found that if you pull up on that little tab too hard, it doesn't return fully back to it's original "shape" and can result in the belt clip coming off more easily later. Use lots of caution removing the clip carefully/slowly... Even better, acquire a holder/holster to carry the unit on your belt rather than the clip.
Unication G5(UHF)
