Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #41 (permalink)
Old 03-25-2017, 4:19 PM
Awesomeeeeeee im ording today, diddnt wannt go 7" and look like a dummy with a long antenna and short radio since i do city bus towing
  #42 (permalink)
Old 03-25-2017, 7:23 PM
radio3353's Avatar
Amazon has it for $19.28
https://www.amazon.com/Motorola-Orig.../dp/B00R8H1YIA
  #43 (permalink)
Old 03-25-2017, 9:55 PM
This would be more appropriate: NAF5084A NAF5084 - Motorola 7/800 MHZ STUBBY ANTENNA - ShopWiscomm
Don't waste money on the APX antenna with GPS you'll never use.
  #44 (permalink)
Old 03-26-2017, 8:42 PM
They 13 bucks at local radio shop in Houston
  #45 (permalink)
Old 03-27-2017, 2:16 PM
Default Nar6595 motorola antenna full bars 17 bucks
It works full bars
  #46 (permalink)
Old 03-28-2017, 9:43 AM
Signal-Zero's Avatar
Hou30guy...which one did you wind up getting ?
"We celebrate our independence from the Government, not our dependence on it."
  #47 (permalink)
Old 03-29-2017, 9:08 AM
DaveIN's Avatar
Founders Curmudgen
Interesting, it works two bars here with the RS800 at full signal bars. I'll stick with the RS800, but thanks for the idea. Looks good by the way.
Pop' Comm Monitoring Station ID: KPC9DV
CRB Research Monitor Station Registry: KIN9GP
GMRS: WQKL769
MARC ID:3126326
The BEST scanner or receiver is the one you using right now.
  #48 (permalink)
Old 03-29-2017, 6:16 PM
I'm using this one over the 7" XTS 800 antenna. I've analyzed both antennas and the 7" is centered around 850 Mhz and the stubby at 700 Mhz. Both are quite good antennas though.
https://www.amazon.com/gp/product/B00R8H1YIA/
  #49 (permalink)
Old 03-30-2017, 6:17 AM
Nar6595
  #50 (permalink)
Old 04-03-2017, 9:15 PM
Anyone having problems going from the NAR6595 and then going back to the stock antenna and having severe signal loss? Confirmed the same with my RS-800. After trimming the Motorola NAR6595 I'm getting great reception. As soon as I switch back to stock or RS800, lose the signal on the systems I monitor. Also confirmed the signal side by side with my PSR-800. Thoughts ?
  #51 (permalink)
Old 04-04-2017, 9:27 AM
Also noticing degradation on stock ant after using NAR6595. I hadn't noticed it prior to your post, as I am out of town and not listening to usual systems. I also have a non Moto 3" stubby that I don't use, as it pulls in signals exactly the sams as the G5 stock ant. Now noticing a significant improvement (2-3 bars) with use of the non Moto stubby over the stock ant. Also seeing only a one bar improvement when using stock ant vs no ant.
Only thought is maybe the 6595 may have pushed the ant pin on the G5 down a bit and now it's not seating correctly in the stock ant?
  #52 (permalink)
Old 04-04-2017, 4:09 PM
I pulled the pin and checked it. Looks good. May have to order one just to make sure I didn't chip it. But the NAR works great so I'm good for now.
  #53 (permalink)
Old 04-04-2017, 9:18 PM
Sounds like the same thing that happened to mine. I switched to the Motorola antenna, then back to the stock antenna, and kept getting out of range errors on systems I had no problem receiving before. I'm now using this sma to bnc adapter with a stubby bnc antenna, and it's working again.
'Motorola 5880384G68 Adapter, Female SMA to BNC'
  #54 (permalink)
Old 04-05-2017, 5:59 PM
cmdrwill's Avatar
Adapters change the antenna tuning.
  #55 (permalink)
Old 04-05-2017, 6:37 PM
Yeah but does an antenna change the antenna tuning? My stock antenna no longer pulls in signals while a OEM Motorola antenna now does. All I did was switch from one antenna to another.
  #56 (permalink)
Old 04-05-2017, 7:47 PM
Same here. I only started using the adapter, since the stock antenna no longer worked.
  #57 (permalink)
Old 04-06-2017, 12:33 PM
b1100mac's Avatar
You guys are making this way too hard...When you change antennas on a G4 or G5,,, you need to either power down the radio, then power it back up OR switch to another knob position and then back so the radio will RE-SCAN that system with the NEW antenna. My 2 G5's both show hearing 2 sites with the stock antenna, when I switch to my motorola and make the the radio do the re-scan it come up with 4.
  #58 (permalink)
Old 04-06-2017, 12:50 PM
Yeah, that doesn't work. I've switched systems, talkgroups, hard reset, etc. Still working great with the Motorola antenna. Nada win the stock or RS-800 with an SMA to BNC antenna. Checked the pin, everything is seated properly. Going to Unication through my dealer.
  #59 (permalink)
Old 04-06-2017, 1:23 PM
cmdrwill's Avatar
I have seen knock off antennas and 'adapters', with bad sized connectors cause problems with the radio connector, AKA damage. Not always easy to see the damage.
  #60 (permalink)
Old 04-06-2017, 1:25 PM
troymail's Avatar
I've been using a RS800 with an SMA to BNC adpater since last weekend. Great reception.
Today, I received and and tried a NAR6595 - the RS800 seems to work better for my current setting and monitoring.
Unication G5(UHF)
