Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 03-14-2017, 7:25 AM
Default Error#02144 message on G5
I am experiencing the same issues as described in the thread "G5 Od behavior when powered off overnight" plus about every third time also receive the following error message. Can't find any RESET, DVR or PLAY keys to reset. Anyone else having this problem?
Old 03-14-2017, 8:03 AM
I had the exact same error a while back with my G4. I also cannot get mine to reset without a battery pull. I was told by Unication Dave that he was checking to find out what the error code meant. I narrowed mine down to a specific system when I turn on Monitor Mode. Once I turn it back off, it stops happening. FYI I never got an answer from Unication..
Old 03-14-2017, 3:10 PM
Unication_David's Avatar
Unication Representative
I've been waiting for a list of error codes from the programmers if and when I receive it I will let you know.
David K. Oney
Unication USA, Inc.
817-210-4187
Please email rather than PM this will insure that I see your message. David@unication.com
Old 06-11-2017, 8:24 PM
Johnnydollar2's Avatar
Default Unication Error codes
Any progress on a "LIST" of error codes David? I see the last post was back on March. I have had my G5 for a bit now and did have that same error, but turning it off, letting it sit for a few minutes resolved that. The only other error I've seen was while sitting in the CHARGER for the G5. Error code #10, use the usb to charge ....etc. I simply figured it was too hot *90 degrees out. I put a small fan behind the charger blowing cool air on it. It only did it again one more time. What is error code #10 while in the Charger? I've looked on line in the G1-G5 documents but couldn't find anything. A separate way to charge a battery outside the pager would also be desired* I must say this product is great. I just came back from a trip using 5 different trunked SITES on the same system using ONLY the stub antenna and it worked flawlessly. Thank You. My "unnamed" digital scanner only got bits and pieces of some transmissions, lots of analog though ;0)
Old 09-04-2017, 7:12 AM
aliby19's Avatar
I had a similar error/reset message appear recently. Googling led me to this thread, but I couldn't find how to actually reset the G4/G5 via key combination.
Through trial and error I found that the reset + DVR + play key combination is both keys on the left side of the pager (as you're looking at the screen) plus the little button sticking out of the channel selector knob.
Hope this helps others, since previously I would have to unscrew the battery door and pull it to reset...
FF/EMT | Hancock Co, IN Public Safety Feed
Radios: Moto 1550XLS VHF, Yaesu VX7R, FT51R, 7800R, FTM400
Scanners: BCD396XT, BCD996XT, HomePatrol-1, Pro-163, Pro-164, Regency MX3000
Old 09-04-2017, 2:02 PM
It's been six months since we were told we'd get a list of error codes. Anyone seen one??
Old 09-05-2017, 2:55 PM
Nope... They won't give me one but I've narrowed it down to an errant command sent by the system that the pager doesn't know how to handle and it happens on very few systems.
David K. Oney
Unication USA, Inc.
817-210-4187
Old 09-06-2017, 6:10 AM
That does make sense as it will only happen on one of my 7 different systems. All the others are OK.
And on my G4 it has only happened when in monitor mode.
Old 09-06-2017, 8:13 PM
wizard of odd
Here's another error code I found today. This was on my built-in car usb charger, supposedly 1-amp.
Old 09-06-2017, 8:35 PM
The unit requires 2 amps.
David K. Oney
Unication USA, Inc.
817-210-4187
Old 12-26-2017, 11:03 AM
WX4JCW's Avatar
I had a charging error, then the error 02144 error occur, somehow it rebooted
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
SDS100,XPR7550,SDR
