Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #21 (permalink)
Old 07-06-2017, 8:13 AM
gdsteele's Avatar
Default G4/G5 Bluetooth
I'm trying to find a bluetooth earpiece/receiver that will pair with the G4/G5, but not think it's getting a phone call every time a transmission comes through.
What are other folks using for bluetooth earphones?
- Jerry
  #22 (permalink)
Old 07-06-2017, 8:14 AM
ecarvalho's Avatar
Plantronics M50 - make sure its the bt v2.1
Icom IC-PCR1000 / BCD536HP / GRECOM PSR-800 / BCD996P2 / TRX-2 / Unication G4 & G5 / SDS-100
  #23 (permalink)
Old 07-06-2017, 9:30 AM
troymail's Avatar
I picked up a pair of these a while back for about $30 just to see if I could get the BT working. It works .. one negative thing is that there is a fixed voice announcement at the start of every voice call advising a call is coming in (I believe this is a standard thing for all devices).
Unication G5(UHF)
  #24 (permalink)
Old 07-06-2017, 10:23 AM
ecarvalho's Avatar
Also...
These work without any beeps / announcement voices or rings:
Docooler 2 in 1 Bluetooth Transmitter & Receiver Wireless A2DP Bluetooth Audio Adapter Portable Audio Player Aux 3.5mm Black https://www.amazon.com/dp/B01FDI8VBI..._PwLxzbDFPSQQD
  #25 (permalink)
Old 07-07-2017, 3:41 PM
Originally Posted by ecarvalho View Post
Also...
I just picked up one of these from Amazon. Easily paired. Sound quality is very good with no extra unwanted noises. Works perfectly, highly recommended. I have been in search of a decent BT receiver, this is it!
  #26 (permalink)
Old 07-09-2017, 8:12 PM
Default Bluetooth Speakers
Has anyone had any luck hooking up a bluetooth speaker to the G4? I turn on Bluetooth, and when I search for the speaker, it never comes up... The only was for it to come up is going thru the "Earpiece" menu...
Once I pair it via the earpiece menu, it still doesn't play properly.
Any feedback?
Ryan S. Olsen
  #27 (permalink)
Old 07-09-2017, 8:18 PM
ecarvalho's Avatar
You can plug any active speakers (amplified) to this bluetooth below or even connect it to your stereo.
It works with G4/G5. I have one here and tested fine. No beeps either.
https://www.amazon.com/dp/B01FDI8VBI...tag=tapainc-20
  #28 (permalink)
Old 07-10-2017, 10:22 PM
Thank you for the information.
Ryan S. Olsen
  #29 (permalink)
Old 07-11-2017, 5:52 AM
krokus's Avatar
- Jerry
The pager gives the initiate call signal, for each received transmission. Now what audio signal your BT speaker/earpiece gives is another matter.
Sent via Tapatalk
  #30 (permalink)
Old 07-11-2017, 5:53 AM
krokus's Avatar
Any feedback?
Does the speaker support 2.0/2.1? If it is BT 4.0, it will not work.
Sent via Tapatalk
  #31 (permalink)
Old 07-11-2017, 8:46 PM
Johnnydollar2's Avatar
The G4 won't do BT 4.0? my G5 does. I've used 2 different BT earphones Jabra classic* and a higher priced brand with horrible annoying "incoming call" announcements that I got rid of. Both were 4.0 and worked. Unication David said in another post that 4.0 is back compatible, you don't need to look for just a 2.0/2.1. Maybe G4 is different?
  #32 (permalink)
Old 07-11-2017, 8:49 PM
@ryolsen8 Did you try making the pager VISIBLE? you click the lower right hand button, scroll to Function Status/select that and then scroll to BT DEVICE make sure it's ON. Earphone shows off. PUSHING SET* below takes it to a new BT DETAIL screen where you push "visible" and make the Pager visible to try and pair it UP for a 2:00 minute timeframe. It counts down/shows Connected device there. This is the G5 but I'm guessing G4 is the same.
  #33 (permalink)
Old 07-12-2017, 4:30 AM
krokus's Avatar
Is this the thread you were thinking of?
http://forums.radioreference.com/sho...d.php?t=352185
Sent via Tapatalk
  #34 (permalink)
Old 07-12-2017, 6:51 AM
I went through a lot of Bluetooth headsets and speakers to find ones that worked without the annoying beeps, blips, and bloops.
This JBL waterproof speaker is the best one that I found for use in my truck:
http://amzn.to/2tdxXjc
This is a less expensive speaker that is not as loud as the JBL:
http://amzn.to/2ui0WYn
This is some headphones that work well for me:
http://amzn.to/2te3BwS
All used with the G5. Unfortunately, the G5 does not work well with the bluetooth system in my car. You also get the annoying beeps and announcements. I will probably buy another JBL speaker for use in the car since it does work very well with loud volume in the truck.
Hope this helps.
Last edited by philcovington; 07-12-2017 at 6:52 AM.. Reason: forgot to add last line
  #35 (permalink)
Hope this helps.
  #36 (permalink)
Old 07-19-2017, 5:51 AM
Default Don't work
Neither the JBL or the Senso work with the G5 (I have both). The JBL won't even connect, and the Senso give you that annoying beep=beep-beep that makes you miss the first part of every transmission...
Still looking for a BT update...
Thanks,
Bill
  #37 (permalink)
Old 08-01-2017, 5:16 PM
Anyone have an update on this? I am looking for BT headphones that will work with my G4 and not have any annoying beeps.
  #38 (permalink)
Old 08-01-2017, 5:20 PM
ecarvalho's Avatar
this has no beeps
you will have to plug a headphone to it
  #39 (permalink)
Old 08-01-2017, 5:28 PM
Default Unication B/T - G4/G5
I use what one other person in here recommended
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's pretty good, kind of cheap but good battery life. There seems to be several different versions of this by different names on Amazon. I still hear some "tubish" sounding transmissions with this just like I do with my other BT headphones and Jabra earphone. I can only assume this is the G5 doing it and the way it handles quick BT transmission, one fast call after another? Anyone else hear this? BUT there are NO tones at all with this, just very faint click sounds in the background. Works well. It's small, the size of a small cellphone so it's not pain. I hook my regular SONY headphones up to it and listen at night. Ahh.. .what HE said... right above me. ;0)
  #40 (permalink)
Old 08-01-2017, 6:29 PM
RRR RRR is offline
This is advertised by Scannermaster as a "Unication bluetooth headset"
Unication Bluetooth Headset | ScannerMaster.com
