Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #41 (permalink)
Old 08-01-2017, 6:34 PM
Thank you!
  #42 (permalink)
Old 08-01-2017, 7:58 PM
radio3353's Avatar
Originally Posted by RRR View Post
This is advertised by Scannermaster as a "Unication bluetooth headset"
Unication Bluetooth Headset | ScannerMaster.com
Scannermaster doesn't provide much info on this other than it is not returnable. Anybody using this before someone shells out $35 plus shipping?
  #43 (permalink)
Old 08-01-2017, 8:38 PM
Hmmmm no description.
Yes, there are stupid questions. Don't ask them.
  #44 (permalink)
Old 08-01-2017, 9:06 PM
Johnnydollar2's Avatar
Default BT for G4/G5
That one for Unication by ScannerMaster has A beep. I remember someone saying so after we all discussed this last time. He said it does have a tone... but it's a short one. The quote is in the search box somewhere.
  #45 (permalink)
Old 08-07-2017, 12:51 PM
6Paul21's Avatar
I just received the G5 and want to use my Bluetooth with this unit. Could someone please let me know how to set up the G5 to pair.
Thanks Ed
Sarasota County Fire Department Photographer
  #46 (permalink)
Old 08-07-2017, 1:21 PM
krokus's Avatar
Thanks Ed
Assuming the menu is the same as the G4, on the Function Status menu, turn on BT Device and Earphone.
Is your speaker/headset/earpiece BT 3.1, or earlier, compatible? The G4, and I presume the G5, will not pair with BT 4.0 and newer.
Sent via Tapatalk
  #47 (permalink)
Old 08-07-2017, 1:32 PM
Hello Ed
G5 and G4 are identical except for the dual band on the G5. Bluetooth yes Krokus explained above will not pair to newer BT devices and beware of the beeping and announcing voice some devices do. Each transmission might start with it and that will get old fast.
Some bt devices work better than others.
  #48 (permalink)
Old 08-09-2017, 9:51 PM
6Paul21's Avatar
I am searching for a BT ear piece to pair with G5. The Plantronics M50 is discontinued. I want one without all the ding and dongs before a transmission.
Thanks Ed
  #49 (permalink)
Old 08-10-2017, 9:30 AM
Default Bluetooth For G4/G5?
Originally Posted by philcovington View Post
...This JBL waterproof speaker is the best one that I found for use in my truck:
http://amzn.to/2tdxXjc...
Phil,
How are you mounting the JBL Flip 3 in your vehicle?
Jim
  #50 (permalink)
Old 12-20-2017, 12:41 PM
I am using the Docooler 2 in 1 Bluetooth receiver, and am getting frequent disconnects. The receiver is sitting right next to the G4, and is plugged into usb for a constant charge. Is there a setting to change in pps to keep it from disconnecting, or is it just the receiver issue itself ?
  #51 (permalink)
Old 12-20-2017, 3:29 PM
Default Humming Sound and Disconnects
I am also hearing a humming sound under the audio !! I tried it out on my Broadcastify Phoenix Police feed, and was hearing a bad humming with the audio.
  #52 (permalink)
Old 12-24-2017, 1:17 AM
krokus's Avatar
That is a "feature" of the pager. It treats every received bit as a new phone call, which is to try and save battery life. I have asked if there is a way to have that user defined.
Sent via Tapatalk
  #53 (permalink)
Old 12-24-2017, 2:04 AM
Default Bluetooth for G4/G5 pager?
@MsWells ... I noticed some of the reviews from the Docooler BT transceiver saying they got frequent dropouts. After having mine for awhile it started doing that with a loud static/clicking sound. Trying to restart it to connect I would get a loud phone call ringing sound. I then read it was a battery saving feature of the pager. Ok? So to beat it at it's own game I turn the G5 "SCREEN TIMEOUT" time to 05 or 06 seconds. THAT saves the battery throughout the day. One time I achieved over 15 hours using that battery saving, screen off feature. During that time the Docooler never dropped out once until it finally ran out of juice itself after it's time limit of 8 hours. I would try that if you're having dropouts where it's right next to the Pager. Use the Screen timeout feature on the Pager and experiment.
  #54 (permalink)
Old 02-23-2018, 10:35 PM
Default Bluetooth gaming headset Yo David!!!!
Hey on the Unification G4/G5 Bluetooth headset issue, in theory wouldnít a Bluetooth gaming headset work because a gaming headset would have 0 setting pertaining to calls? Let me know your thoughts.
Anyone else have a recommendation on a Bluetooth headset or earpiece?
  #55 (permalink)
Old 02-24-2018, 8:45 AM
mdsxfire's Avatar
Originally Posted by ecarvalho View Post
this has no beeps
you will have to plug a headphone to it
https://www.amazon.com/dp/B01FDI8VBI...tag=tapainc-20
Can any of you guys that have this post some video of it?
  #56 (permalink)
Old 02-24-2018, 8:49 AM
Is this adapter battery operated? Rechargeable the amazon listing doesnít show a picture of the back or say whether it is.
  #57 (permalink)
Old 02-24-2018, 9:38 AM
Yes it does. "Battery: Built-in Rechargeable Li-polymer battery(600mAh)
Working Time: 8 Hours (depend on audio volume)
Charging: Micro USB 5V/0.5A"
  #58 (permalink)
Old 02-24-2018, 9:48 AM
Signal-Zero's Avatar
Also...
These work without any beeps / announcement voices or rings:
Docooler 2 in 1 Bluetooth Transmitter & Receiver Wireless A2DP Bluetooth Audio Adapter Portable Audio Player Aux 3.5mm Black https://www.amazon.com/dp/B01FDI8VBI..._PwLxzbDFPSQQD
Hmmmm....since it has a 3.5mm jack, Iím wondering if anyone has tried pairing it to this device and then running a Kenwood KES-3S 5W external speaker from the 3.5mm jack? Thoughts?
"We celebrate our independence from the Government, not our dependence on it."
  #59 (permalink)
Old 02-24-2018, 5:21 PM
You can feed any amp you want with it. 5 watts should give you a decent volume.
  #60 (permalink)
Old 02-25-2018, 7:15 AM
Iím going to give it a try. Will post results once I get everything in and hooked up in the car.
