G4/G5 Amplified Charger USB Port
brucebuck1010
Has anyone tried the USB port on the back of the amplified charger dock? I hooked mine up to my smartphone and it didn't do anything. I took the same cord and plugged into a typical 5V wall wart and it worked with the phone just fine.
JD21960
ILL-annoyed
G4/G5 Amp Charger USB Port?`
If you look at it on the back? IT says 5v. I used it to recharge my Jabra Bluetooth ear phone and it works fine. Must be a faulty unit.
brucebuck1010
Naw, all the phones are 5V. But you are on to the right idea - it's the current that's limited. I was able to charge an external USB battery pack, but again, not the phone. So all is as designed, apparently.
ffexpCP
wizard of odd
Michigan
Manual states it for bluetooth charging. Too low current to be useful for anything else. Disappointing really.
