G- series PPS problems?
Ethan1373
Macclesfield, North Carolina
I downloaded the G series PPS on Friday and it worked great i opened it 10 times or more, no problems. i go to open it on Saturday and it gives me an error message before opening that says PPS has stopped working, this is as soon as you try to open it. the part for the password never pops up? has anyone had this problem? i have tried uninstalling and reinstalling with no change and restarting the computer, I don't know if its an issue with the computer a (2015 Lenovo think pad) or the software?
pike63
Only been using the software for a couple of weeks and have not had that issue. Wondering if it's not your computer. Do you have another machine to try the software on? That would be about the only thing I could tell you to try
APX8000
Sarcastic Member
AES-256 secured
I've had it happen before as well. Make sure you COMPLETELY uninstall it. Then reinstall.
Ethan1373
Reply
Thanks guys for the response, i tried going through and uninstalling everything and downloaded it again. Still gives me the same message G-series PPS has stopped working. I also do not have another computer to download it on! Any other suggestions?
Ethan1373
Reboot/Correct profile
I tried rebooting the computer, still gave me the same message. As far as the profile goes im guessing your talking about computer user profiles in? And yes i have a personal and a guest and i have tried both with no luck. What gets me is i had no problems for 24 hours, its like i have a trial system or something.
APX8000
Sarcastic Member
AES-256 secured
Don't just your uninstaller from the the control panel. Go into your C: Program Files and hunt for it to uninstall. I had the same issue. It appeared that it was uninstalled but I managed to locate remnants in the Program files. Look for G series as well as Unication. Drove me crazy until I found them.
Ethan1373
Worked!
This solved my problem, back up and running thanks to Signal-Zero
troymail
Silent Key
I'm hitting this problem today -- my laptop suddenly crashed for no known reason (probably a Microsoft problem). I had the latest PPS up when the system crashed.... Upon reboot, the PPS won't start (same error situation as above).
I've tried uninstalling, reinstalling (default folder "hung" then seem to finally install) - still crashed.
I uninstalled and reinstalled again -- of course nothing different - fail.
Uninstall and reinstall in different location than the default - crash.
Uninstall - run a registry cleaner - reinstall - crash.
I know some places to look for stuff... will go try and clear some stuff out...
We probably need to document here where these locations are to help others in the future - and also maybe get Unication to address this problem.
troymail
Silent Key
FWIW - I'm back....
I renamed two folders before trying to install again....
C:\Unication (renamed it to C:\xUnication)
C:\ProgramData\Unication (as an administrator, renamed it C:\ProgramData\xUnication)
Reinstalled the latest PPS and it now works (didn't have to reboot).
I suspect something in the Unication data got corrupted when the system crashed....
