I did the firmware, and PPS upgrade today. The system in question is an 800 MHz P25 conventional system, NOT trunked. This system does not use TGIDs, or the like. This system fires their QCII tones across the 800 system, as well as VHF.
I tried to set up this G5 to decode QCII on this system with no luck, because each paging setting is looking for a TGID. And you can't use the default "FFFF" for different tones on different group call IDs because you can't use the same FFFF on all of the different groups. Meaning you can't stack more than one set of 2 tones in one "channel".
Maybe I am not using the correct terminology. Hopefully someone can pick up on what I mean.
