G-5 Conventional VHF Programing
TopFlite
MD/ Washington DC
When attempting to program more than one conventional vhf frequency on one zone and knob position, I run into a conflict between monitor and normal scan not having all of my frequencies available on the scan list.
I have been able to copy and paste some knob position content but not others. I know I have missed something...suggestions please.
JD21960
ILL-annoyed
Unication - G5 Conv VHF Programming
We discussed those ideas here ---->
https://forums.radioreference.com/unication-forum/354127-g5-uhf-scan.html#post2814400
It seems one square *preferably the 1st one of a ZONE* controls up to 16 others each in "Monitor mode" The control box/square should be in Normal scan or priority scan mode.
My example at that link? I started in box two and filled in each knob with a Conventional freq in MONITOR MODE, then went back to the FIRST box of the zone to make that the control square in NORMAL SCAN from the drop down menu at top. Selecting Normal or Priority scan reveals the list to choose from of step #2 in the PPS where you listed your conventional freqs.
Don't forget! if you're using the latest firmware update? you have to make sure to select "TONE" at the bottom for "Alerts" instead of "SILENT" for each square or the audio won't work. ON duty must be on too.
troymail
Silent Key
I believe this is the same thing I had to do. It would be nice to be able to just create a (Normal) scan knob position and include frequencies but it doesn't work like that. I suspect it works this way because you have to assign other attributes to frequencies (analog? P25?, etc.) and that requires creation of an entry in the system with these attributes first.
After playing with the latest firmware and PPS - specifically trying (but failing) to get the QCII feature to work on my local P25 system - it was obvious to me that the PPS screens are built for populating the required underlying database tables and fields vs. for ease of use. That is - the PPS isn't necessarily written entirely with the programming user in mind. Perhaps a third party could come up with something a little more intuitive for the user.
TopFlite
MD/ Washington DC
G-5 Conventional VHF 10-8!
Thank You to Johnnydollar2...for the link which I had missed and for the summary which I followed sucessfully!
JD21960
ILL-annoyed
@TopFlite- Sure thing. Hope it all helps.
