G5 Audio/Display Question(s)
portroyalbirdy
Central PA
Before I start, If what you read below was/is already discussed in some way, please let me know so I don't duplicate post(s)! Thanks in advance!
My dealer is letting my demo a G5 for my area, he has also let me do my own programming to the unit (With his permission) I just recently did the PPS and Firmware update. It didn't seem like much of a difference at first, although, as many have stated, there is a few "Under The Hood" fixes. As time went on, I noticed some issues, which I will explain below a bit better. I'm not trying to complain, I know its a constant work in progress, just checking to see if others are experiencing the same issues!
Unit/County/System Info:The G5 unit I'm demoing is UHF- 7/800 (Using Fully UHF, my county system is UHF Analog 2 - Tone Dispatch and 5 UHF P25 Conventional Repeater"OPS" Channels)
1) Is the FFFF Wildcard still need? I was a little confused on how that was worded on the release notes.
2) I did have the "No audio unless squelch is pressed issue, but as stated, setting that to "Tone" has fixed that.
3) I have a Knob Switch Announcement Issue. On power up, the units will say "Selective Call" which is correct, however, when I switch to Knob 2, also a SC, it does not announce that. (I have check the setting, all reading normal)
4) I have a "Priority Scan" and "Normal Scan" List of my Counties P25 Repeater "OPS" Channels, Aliased "OPS 2", "OPS 3" and so on. I've noticed that when a radio keys up, the ID's are sometimes all over the place. Example: My Fire Dept.'s Engine, "Engine 52" has a radio ID of "5201" But on some key ups, I get a random set of ID numbers, when I know the Engine is talking. Its not just that single ID either, I know what the proper ID's of the radios talking should read out, and at times its not even close!
If anyone else is having these issues, please post!
Any help/tips are greatly appreciated!
Thank You!
portroyalbirdy
Central PA
(1/28/18) An update on this:
(And yes, the PPS and firmware has been updated to the latest version)
Question #1 Is the Wildcard still needed?
Questions #2 and #3 have been fixed with firmware update
Question #4 has been somewhat fixed with the firmware update. I still get random P25 ID's that don't match the radio being used, but it not nearly as bad is it was.
**New Questions**
Is there a way I can have my 2 - Tone "Monitor" spot decode MDC1200 is well as 2 - Tone together? Also can I add MDC Decode to my Scan Lists?
And I have some knob spots set to "Tone & Vib" however, when the pager alerts, it does "Tone then Vib" Any ides why this is?
Thank You in advance!!!
JSsignal16
**New Questions**
I haven't messed with two-tone decode on my G5 yet, but I've set up MDC decode for conventional channels in my scan list and it works very well as it displays the MDC ID of each transmission that I receive.
