Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 09-22-2017, 8:57 PM
Default Missing Transmissions
I occasionally miss transmissions on my G5. For example:
Unit: "335, traffic."
Dispatch: "335."
[Silence]
Dispatch: "500 south Main. Received."
In this particular zone, I have two TGIDs programmed. One is for police dispatch and the other is fire alarm. Any recommendations on what might be causing this? It doesn't happen very often, but it does happen maybe 5-10 times a day.
Jim
Realistic Pro-22 | Uniden BC60XLT | Uniden BC246T | Uniden BCD436HP | Unication G5
Old 09-23-2017, 5:42 AM
troymail's Avatar
Dispatch: "335."
[Silence]
Jim
I believe this is a known issue where the Unication sometimes simply misses the initial channel grant so you don't hear the call. Since scanners already seem to handle this in most cases, we're all hoping that Unication can get this resolved at some point in a firmware release.
Having said that, I also see my Uniden miss responses all the time - typically (but not necessarily limited to) very short messages like "ok", "10-4", etc. Still, the Unication should do better with this issue given it is a more "professional" use receiver (and since, other than scanning talkgroups, it typically is only monitoring a single system/control channel).
I haven't tested it but I wonder if it misses less if the knob position if only monitoring a single talkgroup?
Unication G5(UHF)
Old 09-23-2017, 7:24 AM
I have one control channel, one zone, and one talkgroup in each knob position programmed in my G5. It still misses tranmissions all the time.
Old 09-23-2017, 7:25 AM
troymail's Avatar
Alrighty then - guess this answers that question.
Unication G5(UHF)
Old 09-23-2017, 6:32 PM
Thanks, guys. Hopefully it will be addressed in a future firmware update.
Jim
Old 09-23-2017, 8:58 PM
Exactly. As of now the radio does not allow for 'late entry' which is critical for a public-safety grade radio . . conditions on the control channel can degrade very briefly in a fast fade or multipath interference scenario, preventing channel-grant decode at that precise grant moment, with RF conditions recovering quickly thereafter whereby late-entry would solve the issue and the added delay would be almost imperceptible to the user.. certainly better than a full-on missed transmission.
This is a big problem for public-safety users, not to mention a nuisance for hobbyists.
Old 09-24-2017, 7:28 AM
I can imagine! Hopefully it will be fixed.
Old 09-24-2017, 2:38 PM
CFP387's Avatar
I have also found this to be true. Most of the time my G5 stays parked on the knob position that has our three main dispatch talk groups on it. If there is traffic on two TG's at the same time and one transmission is over before the other, the unit will not pick up traffic on the next talk group midstream. It seems that all talk groups must be silent before the unit can look for activity.
Life moves pretty fast; if you don't stop and look around once in a while, you could miss it!
Old 09-24-2017, 10:42 PM
Unication_David's Avatar
Unication Representative
If someone could pull a DSP log and send it to me it would be very helpful in determining the cause. I would also need the TGID and SUID of the missed transmission. The diagnostics tool should be included in the tools folder of the latest PPS.
David K. Oney
Unication USA, Inc.
817-210-4187
Please email rather than PM this will insure that I see your message. David@unication.com
Old 09-25-2017, 1:27 AM
Signal-Zero's Avatar
Yep, paging talkgroup active but couldn't hear the update from dispatch on the response talkgroup because they were already talking when the dispatch talkgroup dropped. I could hear it on my APX, but no late entry on the Unication.
Which firmware do you want the log from ? It does it on both and I can run it on both.
"We celebrate our independence from the Government, not our dependence on it."
Old 09-25-2017, 9:14 AM
The latest we extended the sample time on it.
David K. Oney
Unication USA, Inc.
817-210-4187
Old 02-04-2018, 9:03 PM
If late-entry capability has been added. . I will buy a second unit under the current promo. Any news on that? Otherwise missing an estimated 2-5% of transmissions due to not having this is a non-starter.
Old 02-04-2018, 9:28 PM
mdsxfire's Avatar
I do believe it was fixed in the last firmware head over to the below thread and either sift through or search for late entry.
V0.93-0.17K-R02 Firmware Discussion
Old 02-05-2018, 7:30 AM
My observation on the late entry issue is this. If I now change from one knob position to another, I will hear traffic in mid conversation. For the matter of missing transmissions altogether, I am still experiencing this at the same rate as before. In my case, 5 or 6 an hour. This occurs when parked on a single knob position which has 1 talkgroup assigned to it. I also have a full signal on the control channel when this happens. I am running the most current software.
Old 02-15-2018, 9:44 AM
Being a newbie with my new G5, I have also noticed this missing transmissions problem. I have only had if for a couple of weeks and it appears to have shipped with the latest firmware. I thought it may have started happening over time but that is doubtful. Being a non-professional, it is only mildly irritating but noticeable.
Old 02-16-2018, 12:33 PM
I had a recent email exchange with David on this. I sent him my DSP log along with details on the dropped transmission issue. I haven't heard back from him, but I don't really expect to. I just wanted to give him the data to hopefully track it down.
If you're also having this issue, it might be best to connect with David and share some diag data.
Old 02-16-2018, 8:16 PM
KR7CQ's Avatar
I've come to the conclusion that the G4/5's are basically the Baofengs of the commercial radio world. And I don't mean that as an insult. The Baofeng radios are amazing for little more than $20. In terms of RX, the Unication pagers mostly accomplish what a professional radio can do....minus the 99% decoding, the voice AGC, not dropping connection sometimes, not sometimes making non-encrypted transmissions sound like encrypted transmissions, etc. I just look at them as doing most of what a professional radio does at a fraction of the price and call it good. If only scanners did as well.
If the Chinese get any better at tech I'm going to start getting scared.
Old 02-16-2018, 10:24 PM
b1100mac's Avatar
I notice missing some units responding back to dispatch, but I am only listening to the strongest site to my area. Is it possible the reply transmission is from a unit whose radio is affiliated to another site? IE: dispatch hears them and I wouldn't?
Unication G5 UHF Phase ll times 5
Old 02-16-2018, 10:37 PM
KR7CQ's Avatar
Maybe. I've actually noticed that the Unications work best a fair distance away from the transmitter (could just be me though). Sitting right near the tower, bad things tend to happen. These pagers seem to be at their best with slightly weak to mid range signal strengths, at least for me. For my home PD, at home, I'm quite a ways from the nearest Glendale site, but I get EVERY transmission. Sitting within visual sight of the Phoenix simulcast site while at work, I have all sorts of issues...maybe a half dozen times a day.
