Priority tg in monitor mode G5
vocoder
Indiana
I have tg's programmed in and priority tg checked for yes, set up as tg scan mode on a G5.
Will the top of list priority tg still work if I manually select monitor mode?
maus92
The OP
When setting up TG Scan, you can enable Priority TG ID Option. The way I understand the feature is that the first TG in the Members List will have priority over the other TGs, Further, the second TG has priority over the third TG in the list and so on. My question is will the radio switch from an active TG (of a lower priority) to a TG with higher priority immediately, or does it wait for the end of the transmission?
IAmSixNine
Dallas, TX
If you have priority enabled, it will switch during a conversation.
I have a zone set up with local FD.
Position 1 is dispatch, ops 1, ops 2 and so on. It scans them.
Position 2 is Dispatch only.
Position 3 is Ops 1, Ops 2, Ops 3, Dispatch.
I have them in that order so if a fire call goes out and i want to listen i can go to Position 3 and the ops channels will have higher priority. So if Dispatch is talking and they talk on Ops 1, Ops 1 will then be the higher priority and pass audio.
maus92
The OP
Follow up question: In your last scenario, (knob position 3, listening to dispatch) if a convo starts on Ops2, the radio will immediately switch to Ops 2 because even though it is not the first TG programmed, it is higher in the TG list, thus a higher priority, correct? In other words, priority is inhereted by the order in which the TG is programmed, and priority is not limited to the first TG entered?
IAmSixNine
Dallas, TX
Correct,
Priority is selected as top talkgroup has highest, then goes down from there.. so in my programming ops 2 is higher then Dispatch which i set as the third talk group from the top.
if you have 25 talk groups, then number 24 would have higher priority then 25 as well
