Out of range?!
JRush311
Monroe, N.C.
Unication G5 here
what is the issue with monitoring 700 frequencies?
there are 2 systems near me
Charlotte UASI and NC VIPER(shp)
UASI I can pick up all the simulcast counties but stanly county will not pick up even if I drive into the county
its a 700mhz freq
NC VIPER I can pick up all the towers except again the 700 freqs
whats the weird issue here? its not a distance issue because I have travelled well within range
the only thing in common is the 700 freqs
all the other towers and counties are easily picked up from my home
JRush311
Monroe, N.C.
frequencies that wont work are outlined
JD21960
ILL-annoyed
Out of Range? Unication
IN the PPS. Step #2 under P25 Trunking System Setting you should re-check your WACN ID, System ID and under SITE list double clicked* you need to review the RFSS ID and SITE ID. Of course under Control CH list, review that the correct CChannels are listed.
JRush311
Monroe, N.C.
everything is entered correctly
I double checked and copied the numbers directly from RR database
they work great in all the other counties
and the non 700 freq on viper system
its always the 760-799 numbers that wont work right
IM in Union County NC if you need to view the database
APX8000
Sarcastic Member
AES-256 secured
Look at your 3333.jpg and change 11 to B. Let me know if that solves it.
JRush311
Monroe, N.C.
Thanks a lot I’ll try it when I get home
Very odd that the others work being listed as the appropriate number
I think you’re onto something tho
troymail
Silent Key
Hex vs. decimal has caught me a few times -- and I really should know better. Other times, I found RFSS/site data on RRDB to be incorrect.
If that doesn't work, try FF (wildcard) fir RFSS and site values.
I have several VIPER sites around me that work equally well/poor on the Unication including a 700 Mhz site.
G4guy5891
G4 out of range overnight
Has anyone experienced your G4 going out of range on a system that was previously working?
I did not make any changes to programming but now York County, SC is showing out of range??
I have not traveled out of the coverage area for this system. Any suggestions?
KM4WLV
Rockwell (Rowan County), NC
Do you have both the primary control channels and alternate control channels programmed into the pager? If not it's possible the control channel could have rolled to one of the alternates and that's why you're getting the OOR indication
troymail
Silent Key
Yup - control channel frequencies are the obvious thing to check.... things do change from time to time - particularly in the data posted on RR since it relies upon locals to find and submit information on a volunteer basis.
Not sure what the rest of your programming looks like but I also encountered issues with other system characteristics/settings that changed - not that this is what happened in your case.
I was traveling checking out systems in other areas (York PA) and getting "Out of Range". Turns out, in at least this one case, the information posted on RRDB for site Ids was old or bad - once I fixed that, the Out Of Range went away. For the most part, settings like RFSS and SiteIds are not something most users care about so if/when they change, it isn't likely to get updated.
Beyond that - as recently as yesterday - I was seeing a "flash" of red on the bottom of the G5 display at the end of nearly every voice call. As I looked more closely, for reasons still unknown to me, the red was a "Out Of Range" message which made no sense since I was monitoring the site. I have no idea why this was happening...
G4guy5891
After entering all control frequencies for York Co. the red “flash” was still appearing. Only after changing the site ID from 1 to wildcard “FF” did the signal appear and voice calls resumed! Does anyone know how to verify the correct site ID for a system?
KM4WLV
When you were programming the pager did you use the information in the DB here as far as frequencies, RFSS ID, Site ID, etc?
Sent from my iPhone using Tapatalk Pro
