G5 Charger Amplifier issue
PVPD730
Whenever I attempt to use my G5 in the charger amplifier, 9 times out of 10 I get a flashing "out of range" message. Strange thing about this is it only happens when the supplied antenna is hooked up to the back of the charging unit. Once I disconnect the antenna, it seems to function normally. My G4 doesn't have this issue. I double checked my programming, and everything is correct. Anyone else had similar experiences? Any ideas on how this can be corrected?
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
I just got my charger amplifier for my G4 and noticed when I use the charger antenna with an 800 MHz antenna there are out of range issues but when I only use the radio's antenna everything is fine.
rvacs
Tulsa, OK
Wow W8RMH !!
I just posted this in a new thread.
Also get out of range issues....was thinking because I have not cropped the antenna yet in size for 800 Mhz. but your saying if you just take the antenna off the charger then all is well?
W8RMH
Wow W8RMH !!
I believe the amp antenna connection is for VHF/UHF only. For 800 it uses the unit antenna. Connecting an 800 antenna to the amp unit did not work at all.
I also found a professionally tuned 800 MHz. Motorola antenna on eBay that greatly improved reception (+1 to +2 bars) on the radio itself, over the supplied antenna.
https://www.ebay.com/itm/V08-800-MH...462943?hash=item3d12ec05df:g:8ksAAOSwDuJW0koJ
