Something to play with....
Here's a profile I just created - something to start with/look at.
I am not in Arizona so I cannot test it beyond editing in the PPS and loading it to my G5 (which loaded up just fine).
Disclaimer: as titled - something to "play" with - I wouldn't do alot of editing until you get your radio and try to load this configuration "as is" and make sure the basic functionality works as expected. Then, you can consider makings lots of changes (zones, knobs, etc.).
If you get something from someone local that works, it may be preferred over the attached profile.
The advantage of the attached profile is that all 17 sites and 304 talkgroups (TGs marked encrypted in the RRDB are ignored) are included in the profile.
If anyone in the area that already has a G4/G5 wants to give this a test run, that would be great. Feedback is always welcomed.
