G5 Pager
JD21960
ILL-annoyed
G5 - No sound
After the last firmware update you now have to set "TONE" for each talk-group or it won't have sound. No, there's no on/off for sound on the pager. Has to be set in the PPS, then uploaded for ALL talkgroups. Each box you create in tab 5 must have TONE on too in the controls. I used to have mine set to silent. Then they changed it on us.
as discussed HERE ---->
https://forums.radioreference.com/u...cial-latest-g4-g5-firmware-pps-thread-10.html
JD21960
ILL-annoyed
G5Pager
Sadly yes. They changed it last firmware. It IS a pager after all and other changes they made to the tones and alerts effect everything. Be happy. One guy had to change 4000 talk-groups. I only had 10 Zones, maybe 350 talkgroups. I didn't find any large batch editing way like even EZScan has. The alert MODE is the thing that changes it from muted to sound. The Alert Tone for all of mine in the pic above are at "none" because I'm not using it as a pager like the 1st responders do.
