G5 alerting any time there is voice traffic
KX4KDH
Powells Point, NC
Here's an odd one. If I set up my G5 for p25 trunking scan, or monitor, it will alert anytime there is voice traffic. However, if I set the alert mode to "silent", it will not pass any voice traffic.
Has anyone had this issue?
KX4KDH
Powells Point, NC
Okay, I figured it out. In the group ID settings, you have to change alert mode to "None". That does the trick.
Now to figure out why it passes traffic from other talkgroups than what I assigned while it is TG monitor, and not TG scan.
IAmSixNine
Dallas, TX
Isnt TG scan, the way to scan what TG you have in the list.
TG Monitor is the wildcard scan that opens up to every TG on the system.
But i could be wrong.
KX4KDH
Powells Point, NC
TG Monitor will stop on all traffic, TG scan only stops on talkgroups you have in that particular knob position.
Ohhhh, I get it now. Even though the wording doesn't make sense. Great, now the customer is going to say "Why does it say scan when it is only showing one talk group?" Ugh....
I'll give it a try.
KE4ZNR
Radio Geek
I'll give it a try.
You coastal techs and your toys :D:D:wink:
Marshall KE4ZNR
mdsxfire
EDBM
Uxbridge, north of the river Thames
Also I thought I read somewhere that if u left both alert settings to none that no voice will come through at all after the last firmware update.. I’m just trying to narrow down wich setting I should have it set to if I want zone 1 knob position 1 to scan only my FDs TGs and wich setting of zone one knob 2 I want to hear all traffic on every talk group in that system.
jim202
New Orleans region
I recall something in David's video from September about this but I don't remember the specifics since two-tone over P25 doesn't work on my system here.
I am not trying to hijack the thread here, but thought it is a comment about your P25 system not passing 2 tone over the system. It is being used here in Louisiana and works reasonable. But the audio level of the tones is critical. If the tone level is too high, it will clip or just get distorted and not get decoded.
mdsxfire
EDBM
If our old VHF dispatch channel is patched into our new TG , being that the VHF is going to be used for dispatching calls only, when our tones are put out will that carry over to the digital TG and alert the pager if I enter it as a 2 tone QC?
ResQguy
Meh
That depends on how it's set up in the console. We only send tones on the VHF side currently, but a neighboring jurisdiction sends them over VHF and 800. Your agency will have to do a study on what works best for them.
mdsxfire
EDBM
As of now the old VHF dispatch/ops channel will be fully patched to the new p25 ops TG, so anything that is broadcast on the vhf will go over the TG, I’m just wondering if the tones will “translate” over the digital TG. I’m would think that they will broadcast over the p25 TG just not sure if it will alert the pager
ResQguy
Meh
If the tones are coming directly from a Motorola console at SR7.16x or higher, probably will work fine. If coming from a third party tone encoder injected into the console somehow, who knows?
mdsxfire
EDBM
Fair enough.. im not exactly sure what the console is anymore. we are going to a Harris P25 system so they were in there replacing HQ's console with some harris equipment so who knows.
Thanks for the reply
ResQguy
Meh
May the odds be ever in your favor then! It's certainly worth a try.
