mdsxfire
EDBM
Are there any decent statewide systems from New Jersey to Florida that would be worth programming and get traffic monitoring all TG while in that state.we drive downt to Florida every year and I was wondering if it would be worth it.
Viper in NC and Palmetti P25 in SC, both would be good along I95.
I've done this type of thing with scanners for several years when driving from Marlyand to southeaster North Carolina and back again. Seems like there should be an easier way.Wow!!! Those are huge systems. I guess the best way to program them for the ride is see which counties 95 runs through and program those sites?
For the full spectrum scan is that programmed like a regular system with a range of frequencies or is there a specific tab for that type of program. And when doing that is is TG scam or TG monitor to get all TG on thatbsustem
Ok so if I specify the system ID and wacn and put the full frequency range but wild card the sites and TG it will pick up everything, will it also jump to different sites within the system as I driveIt works the same as creating any system. The only difference is that instead of supplying specific frequencies, you enable Full Spectrum Scan and then frequency ranges you want the radio to search.
If you set the WACN to FFFFF, the Sysid to FFF, the RFSS to FF, the Site to FF and include a wildcard TGID (FFFF), the radio will look for and lock onto any P25 system (almost) that is in range.
As I said, there are negative aspects - Phase 2 systems (silence), no alpha tags, locking onto something you don't want, etc.
However, you could go middle ground, create a couple of systems (use the COPY button), and add some of the system attributes like WACN and Sysid to the COPY while keeping everything else wildcarded and place these in different knob positions. That way, you an search for and lock onto that specific system should you choose to do so.
Consider the possible combinations.
You can use TG Monitor (I believe) or add a wildcard talkgroup ID (FFFF or 65535) to have the radio stop on any active talkgroup for the current system (configuration) you are monitoring.
Generally, yes.
Ok, I understand there will be some issues but it’s something else to listen to when everyone else is sleeping and I’m driving. I’m assuming when doing this I leave the control channel list blank as it’s doing a spectrum trunk
Correct, you need not enter any control channel frequencies if enabling Spectrum Scan.
About the only thing you can't work around with this is encryption -- when it starts up and I am in any kind of wildcard mode, I just turn the radio down...
TG ScanHopefully my last question for a few hours
If I want say zone 1 knob 1 on my County system and only pick up the TG I have programmed is the receiving mode trunking TG scan, trunking TG monitor or free scan?
And under group I’d setting should alert mode and alert tone be “none”
TG Scan
I leave "Alert Mode" set to the default "Tone" and change "Alert Tone" to from "Default Tone" to "None".
and your audio comes through with no issues with that setup correct. i was asking because i read that people were having issues with no audio coming out set to "none" None" after the last firmware update.
thanks for all the help
It hasn't been a few hours yet, has it ? :lol: (oh, it has been almost two hours!)
Yes - works fine for me with those settings.
