G5 Charging Error #10 on new firmware...
yfdgricker
Youngstown, Ohio
Anyone else experiencing a Charging Error #10 when charging in the amplified drop in charger with the latest firmware (17K-R02)? The message pops up on the G5 as soon as I put the unit in the amplified charger. It will charge just fine when using the charging cable. I had no charging problems or error messages under the previous firmware. The device will not charge at all when in the drop in charger.
Thanks!
IAmSixNine
Dallas, TX
Re-flash the firmware, then shoot new programming into it from the saved info or from the import.
Then do a battery pull and retest charger.
I seem to recall having an issue with my drop in charger a few firmware updates ago and re-doing it fixed the issue.
a1emt
Same thing I was thinking [emoji41]
Jim
yfdgricker
Youngstown, Ohio
Will do guys. Let me try your suggestions and see if it helps.
This was before I tried your suggestions: the battery is not holding a charge for more than a day regardless of whether I charge via the drop in amplified charger or the cable. I rolled back to the previous firmware which no longer gives me the error message but the battery life is still bad.
