Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #21 (permalink)
Old 02-01-2018, 9:50 PM
Signal-Zero's Avatar
Hmmm... never seen that. The only thing I can think of is that even though itís max 14 characters, the Unit is interpret it as a larger string of characters due to the varying font size between upper and lower case. Try removing one character and see if it holds the line.
I have an APX as well and I shorten all my alpha tags or the font size will decrease. Some that are the same exact character length appear larger or smaller than others so thatís where Iím getting this possible fix from.
"We celebrate our independence from the Government, not our dependence on it."
  #22 (permalink)
Old 02-04-2018, 3:40 PM
MrRadio's Avatar
First, I want to thank all of you that assisted me with programming my G5.
After the 5th code-plug/file, I think I have it 95% of the way I want it.
I HAVE reprogrammed the alpha tag a couple different ways for that one monitor channel in the scan group that is getting cut off but nothing has fixed it.
If anyone has another idea let me know.
I think it might have something to do with having so many capital letters in it, or, the way the radio displays the monitored channels from a programmed scan knob position.
I must say that overall, I'm VERY PLEASED with the G5.
I just hope we/they can somehow add programmable talk-group delay and hold in a future firmware release. For delay, maybe even just a global delay per zone.
Dave D.
(Former 911 dispatcher)
Unication G5, BCD325p2, BCD396T, BC796Dx2, BC780XLTx2, AOR AR8000, RS Pro-26
Pro-2042/Opto535/Probe, Pro-2006/Opto456/Probe, Pro-2066, BC9000XLTx2
  #23 (permalink)
Old 02-17-2018, 1:51 AM
Default Help Unication G4 and PPS
Hey ladies and gentlemen I can't find my "model number" in the PPS drop down.
My model number is: GS442RE-SXXXEN1500UNI
any advice? Which model should I use?
Jeff
  #24 (permalink)
Old 02-17-2018, 3:03 AM
mdsxfire's Avatar
Originally Posted by Signal-Zero View Post
I will tell you planning is the key otherwise you will be using copy and paste a lot. I have mine set up for my specific needs. For example, one City I have SCAN-ALL, SCAN-PD, SCAN-F/R, then one talkgroups for PD MAIN, PD INFO, PD TAC, FIRE MAIN, FIRE TAC. On a large Statewide system like NC VIPER, I have one zone that scans only NCHP that covers I-95, same for Palmetto P25 for SCHP in the next Zone. Then all the other knob positions in those zones are basically each County along that route (PD, FD, Sheriff Main and select others as well as HP). This way I can switch knobs at the County line.
Planning and playing with the software is definitely a plus and a great way to learn the software and how u want it to be setup, now if only I had a pager to program.... címon phase 2 update!!!
  #25 (permalink)
Old 02-17-2018, 7:15 AM
troymail's Avatar
Jeff
There is only one option for G4 profiles in the drop down.
Unication G5(UHF)
