G5 Possible Birdie
N9JOD
I have a vhf conventional frequency (156.00000mhz) programmed in a knob position. I'm using ctcss 107.2 tone. I hear what clearly sounds like a birdie. But then, I thought it may be local rfi here. So I did the normal things you do to track down the source. After nothing was found, I programmed another receiver to see if anything was heard on that receiver. Nothing was heard. I then took the pager for a drive out of town and I still hear what I believe to be a birdie on this frequency. I also tried changing the tone to 114.8 with the same results. I'm not surprised or shocked by it. Has anyone else ran into any while programming? I guess if someone else programs this into their G5 it may help to confirm it.
- Darrell
JD21960
ILL-annoyed
If the code is being used 114.8, 107.2 or any other, why would the sound be coming thru? Nothing should be heard if the settings are right in the PPS in #5 zone blocks under Squelch Type - If you used the setting "NONE" instead of CTCSS that's the only way you would hear open squelch birdie noise? must be local then
N9JOD
Many years ago Motorola had a similar issue with the HT1550 XLS that would do roughly the same thing. But it would only manifest the problem when you used 114.8 tone. It's took some time, but they fixed the issue in a firmware update. I'm not totally sure what it is.
