Unit ID displays
PVPD730
Ours will display P25T when dispatch initiates a patch or multi-selects two (or more) talkgroups.
JSsignal16
Select tab 2 Frequency & System Setting: Enter the conventional frequency you wish to use under the Conventional Frequency Setting tab
Select tab 3 Protocol Parameter Setting: Click new and select MDC 1200 then label it "MDC 1200" and save it.
Select tab 4 Group ID Setting: Click new then select from the MDC/UFC TGID column. Enter 65535 (FFFF) then give it a label under group alias. Make sure you set alert mode to tone and set alert tone to none. Then uncheck voice storage if you don't wish to record. Then save it.
Select tab 5 Zone & channel setting: Select a knob position you wish to use. Set receiving mode to monitor mode. Assign an alias to the knob position. Select the frequency you wish to use. Change protocol setting type from CSQ to MDC 1200. Set a squelch type CTCSS or CDCSS if there is one. Then scroll to the bottom. Then under Knob Talk Group List, select the MDC ID you created in tab 4 by clicking the box under enable. Then save it and and program it and you're done. Your G5 should be decoding MDC 1200 from every transmission that has it when that knob position is selected. Any transmission that doesn't have it will show CSQ.
JSsignal16
Select tab 4 Group ID Setting: Click new then select from the MDC/UID TGID column. Enter 65535 (FFFF) then give it a label under group alias. Make sure you set alert mode to tone and set alert tone to none. Then uncheck voice storage if you don't wish to record. Then save it.
troymail
Silent Key
Ah -ok - I had to read up on the term "MDC" ... so, based on the above post, if these digital bursts are sent as part of the transmission, it would seem the Unication will decode that burst.
I'd be interested in seeing a video of this in action if someone can do that.
RRR
OFFLINE
USA
Is there any way to program UID's to show alphanumeric?
mdsxfire
EDBM
Uxbridge, north of the river Thames
Nope. It’s on the list of “requests” but not a priority.
It’s still a pager so as a pager most users aren’t worried about uid. I’m just glad it works as well as it does on the systems I monitor. I have around 170 TGs I don’t really want to program thousands of uid for all my TGs lol that would take days.
APX8000
Sarcastic Member
AES-256 secured
I’m sure if they included that option they would implement an import of a .csv file function just like every other manufacturer.
