Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #21 (permalink)
Old 06-29-2018, 12:04 PM
Hi I have this issue now a couple of times as well. This error came up after turning on the unit not even just after charging, with a brand new G4 unit with Phase II firmware built in...i pressed the two side buttons and the top play button to force a reset and it wouldn't take that...the easiest solution since I was in front of the computer was to send it the programming again to force a resetart, didn't want to take the battery out. Hope Unication can fix this quirk.
  #22 (permalink)
Old 06-30-2018, 7:32 PM
KR7CQ's Avatar
I have the issue, it seems to be happening a bit more often, and it's getting more irritating as turning off and on no longer works, it either takes a battery pull or dumping the program back in. For me it typically happens when I simply turn the device on, then it goes to the error.
  #23 (permalink)
Old 07-06-2018, 12:33 PM
KR7CQ's Avatar
The latest firmware V1.10-T06 seems to have (almost entirely) fixed the issue. I saw the error come up for maybe a half second once when I turned my G4 on, and it vanished very quickly. Other than that, I haven't see the issue return in the last week of testing. I'll update if there is any change.
  #24 (permalink)
Old 07-11-2018, 11:53 PM
Where can I get 1.10-t06? I'm on1.00.t08
  #25 (permalink)
Old 08-12-2018, 5:34 PM
Error code FFFFA today; unable to clear with any button presses or trying to load another zone.
Turned the unit off and on several times with the error screen showing up again.
Didn't have any tools to take the back off.
Finally turned it off and did something else for about 2-3 minutes, turned it on out of boredom and it came on no issue.
I have Phase II software and it's a G5.
  #26 (permalink)
Old 08-13-2018, 10:42 AM
Ive noticed a couple times after it sits for maybe 5 mins it will reset it will do it right after programming
  #27 (permalink)
Old 08-19-2018, 8:22 PM
Chiming in so I can stay up to date on the firmware update. My G4 is only a month od, and I have experienced this same issue 4 times. first 3 times, it self-corrected itself after 2-3 minutes. Today it did not, the "3 button press" did nothing, so a battery pull fixed the issue. In my opinion, a $565 receiver shouldn't have issues like this.
