Pairing the G4 with an automobile Bluetooth system...anybody try this yet with success? I am going to try this on my 2014 Toyota Corolla when I have a chance, but I thought I would ask if anybody else has done this yet in their auto. Thanks.
If you have a standard "line-in" jack and "aux" setting on your factory car radio, may I suggest a Bluetooth adapter that is wired to the line-in slot? I have found these solutions to be much easier to pair for other devices and do not ring or have an audio alert like factory units when there is incoming audio. Fewer headaches and it never pairs when you don't want it to. Plus, this solution allows a dedicated phone to remain paired with the head unit.
I got it to pair with my 2010 Escape's SYNC, but it rings like an incoming call before every transmission. This is a known issue with bluetooth headsets, so I wasn't surprised. Needless to say, it wasn't useful.
Will the Unication pair with it?
Sent using Tapatalk
I read a post somewhere that Unication devices will only work with Bluetooth 2.1, can anyone confirm this.
Thanks, Mike. I have this Bluetooth adapter at home that I use to pair the G4 with an external speaker:
I bought the docooler Bluetooth transceiver from Amazon but having trouble getting it to connect with my non-Bluetooth device it pairs with the G4 OK but when I switch from receive to transmit it doesn’t go through I am supposed to have it hooked up to the red 3.5 jack correct?
