G4 Sluggishness after Phase II
rvacs
Tulsa, OK
So just curious...had a G4 before the Phase II firmware.
And worked normal.
Then sold that unit.
Then got another G4 with Phase II firmware.
Used same profile as before in PPS.
Now when say I adjust the volume there is a lag. (before it shows volume level on screen) Or say I am doing other functions on the radio itself there seems to be a bit of lag that wasn't there on my previous non Phase II unit.
Has anyone else noticed it? Not complaining too much - just curious.
IAmSixNine
Dallas, TX
I have made very few changes in my 2 G4 units, so for me the before Phase 2 and after Phase 2 update i dont notice any difference.
radio3353
My G4's screen tends to be a bit sluggish. I purchased my G4 with the Phase II capability installed so I have no comparison to a non-P2 unit.
Uni1
Unication Representative
DFW Texas
And worked normal.
I sent you a PM.
N6ML
Same as radio3353 - I bought my G5 with Phase-II, so have nothing to compare, but did notice that the on-screen response to volume adjustments is laggy. Another oddity that I've noticed is that sometimes twiddling the volume control will wake up the screen immediately, sometimes it'll wake up after some seconds, and sometimes it won't wake up at all..
Jimco
Dallas/Fort Worth
Moving the volume knob has never waked my screen. I will only see the volume bar while turning the knob if something else wakes the screen, either a transmission or pressing a button.
eorange
♦Insane Asylum Premium Member♦
Cleveland, OH
I noticed that when I started having a "large" number of talkgroups...the volume went from normal to more sluggish and not waking up the screen. Probably when I started to exceed about 150 TGs? Not sure though. This is on a G4 without Phase II.
N6ML
I have only 26 TGs defined, and no more than 9 in any single knob position list.... FWIW...
b1100mac
Premium Member
Corvallis, Montana
Simple solution to volume bar: tap the toggle button, adjust the volume, and you are done, I own three and it is and has been that way from day one for mine
N6ML
Yes, that's what I've been doing ... but the point is that the behaviour is inconsistent, which is indicative of an underlying problem.
rvacs
Tulsa, OK
Ok - Those guys at Unication Rock.
A simple firmware re-flash and running great !! I should have known.
All is well - even taught me a new trick or two.
Now if I could just get my local city on AES encryption instead of the crap encryption they are on. (LOL).
rvacs
Tulsa, OK
Yes...same version did it.
I know seems weird but it is a whole different machine...
Loving it.
radio3353
My mind is mush today. How does one re-flash the firmware? Thanks.
N6ML
There's a ZIP file in the "Image" subdirectory of the Phase-II dropbox. It includes the tool to flash the image. I just did mine. I'm skeptical, but will see if it makes any difference. Don't blame me if you brick your unit, though. If you're in any doubt, have support walk you through the procedure.....
