billpritjr
Scanner user since 1985 here. Used them/had them all. Radio Shack, Bearcat, etc. Also Amateur Tech class holder, owned Alinco's and Yaesu's over the years. Not "my first hay ride" when it comes to radios.
With that said, I get fatigued pretty quickly trying to keep up with the recent trunking scanners. I like the home patrol but the purist in me says the radio in my palm should be field programmable, not require I be close to a USB port to listen to a frequency. And if I have no real choice, I want the radio to work as expected.
My "target" is Dallas-Ft Worth area public safety, mostly FIRE, because if it is "big" they will send a fire truck. I am not interested in listening to law enforcement prowler calls or gas drive-offs at 7-11, in between major incidents. My primary system will be Denton County (link: https://www.radioreference.com/apps/db/?sid=8438), note the following disclaimer:
I am intrigued by the G4/G5 device, what do you guys recommend
Thank you
The new system uses P25 Phase II modulation, and requires a newer digital type of scanner that can decode radio traffic on this system. Currently, the following scanners can decode P25 Phase II and Motorola X2-TDMA systems:
* GRE PSR-800
* Radio Shack Pro-668
* Uniden BCD436HP, BCD536HP, HomePatrol-2, BCD325P2, BCD996P2
* Whistler WS1080, WS1095
Thank you
