Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #41 (permalink)
Old 07-09-2018, 6:33 PM
dseven's Avatar
I got the 8505241U11 off eBay. I can't say it really makes a significant difference - marginal signals on the stock stubby seem equally marginal with it.
How are you guys getting useful RSSI readings? The diagnostic screen seems useless to me - it's either "> -100" or -113 and "Out of range".
  #42 (permalink)
Old 07-09-2018, 7:25 PM
NC3Z's Avatar
Hmmm, my RSSI seems to read well, quick real time updating in 1dB steps.
Gary NC3Z
NC AHIMT COML
  #43 (permalink)
Old 07-09-2018, 7:26 PM
Let me check mines since i have the 4''
Sent from my SM-N950U using Tapatalk
  #44 (permalink)
Old 07-09-2018, 7:37 PM
Where do i find these readings, cant seem to find it
  #45 (permalink)
Old 07-09-2018, 7:46 PM
NC3Z's Avatar
Diagnostics under the 3 "bubbles", then scroll to page 3 of 4.
You may have to wait for a TG to become active.
Gary NC3Z
NC AHIMT COML
  #46 (permalink)
Old 07-09-2018, 7:52 PM
Unication Representative
You have to enable them in D 6 on the PPS.
  #47 (permalink)
Old 07-09-2018, 7:58 PM
dseven's Avatar
Do you get values greater than -100 (e.g. like -80)? I think I read somewhere that anything above -100 is considered adequate, so not useful for diagnosing reception problems. It would be very useful for comparing
antennae, though :/
  #48 (permalink)
Old 07-09-2018, 8:08 PM
This is all great information. Our stubby is designed to give the best reception on a wearable device. Obviously, it can be improved. Our U3 antenna I much better but is cost prohibitive (GPS) and needs to be trimmed. We are working on longer antennas for our upcoming products that will fit the current G4/5.
  #49 (permalink)
Old 07-09-2018, 8:38 PM
NC3Z's Avatar
antennae, though :/
I get -100 and then <100, and of course -101 on down.
Gary NC3Z
NC AHIMT COML
  #50 (permalink)
Old 07-10-2018, 1:31 PM
NC3Z's Avatar
Well with all this antenna testing I have somehow managed to kill the stock stubby antenna. I have done nothing more than remove and replace the stock numerous times. Now it get zero signal, but the other antennas I have been testing work just fine so I doubt it is the G4's connector.
I have already contacted Ray's pager and they are looking into it. But kind of weird.
Gary NC3Z
NC AHIMT COML
  #51 (permalink)
Old 07-10-2018, 1:57 PM
dseven's Avatar
Try screwing the stock stubby on all the way, then backing it off about half a turn. Does it come to life?
Mine that does after I've used a Motorola antenna (green base). I don't really understand why it would lose the connection when fully tightened... unless something is causing it to short? but I don't know what that would be. I've inspected the pin of the SMA connector under a magnifier and can't find any evidence of trauma. Whatever the issue is, so-far, it seems to resolve itself after a while (some minutes). It's quite strange....
  #52 (permalink)
Old 07-10-2018, 2:00 PM
NC3Z's Avatar
Did all those gyrations, no joy.
Gary NC3Z
NC AHIMT COML
  #53 (permalink)
Old 07-10-2018, 2:02 PM
dseven's Avatar
Do you have another radio to try the stubby on?
Keep us posted on the outcome. I'm worried that mine is going to fail outright some day too.....
  #54 (permalink)
Old 07-10-2018, 2:10 PM
NC3Z's Avatar
Had to make up some adapters but just tried it on another RX, it is dead ;(
Guess I should not have messed with it.
Gary NC3Z
NC AHIMT COML
  #55 (permalink)
Old 07-10-2018, 2:15 PM
Thats a easy fix, get something thats small enough to push that needle in the radio antenna hole to the left or right just a hair and back full signal with ur stock antenna
  #56 (permalink)
Old 07-10-2018, 2:59 PM
NC3Z's Avatar
No joy either, but also as noted about the stubby does not work on other radios either.
Gary NC3Z
NC AHIMT COML
  #57 (permalink)
Old 07-10-2018, 3:32 PM
If u didnt move it enough to get signal backthen u didnt move it
  #58 (permalink)
Old 07-10-2018, 3:54 PM
NC3Z's Avatar
Not comfortable with trying to bend the pin, should not have to on a brand new radio. Will wait for Ray to work out a replacement antenna.
Gary NC3Z
NC AHIMT COML
  #59 (permalink)
Old 07-10-2018, 3:55 PM
NC3Z's Avatar
On another note I ordered one of the 4" 7-800-GPS versions to test out. For $8 it's worth a go since some of you have made fun of my "big" antenna!
Gary NC3Z
NC AHIMT COML
  #60 (permalink)
Old 07-10-2018, 4:00 PM
And that new stock antenna wont work either been there done that but ok, something with the aftermarket antennas then going back to stock does it, just a slight move and u back to full bars. Remember i told you so when the new antenna comes
