Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #61 (permalink)
Old 07-11-2018, 12:20 AM
I honestly find this thread to be weird/surprising. My stock G5 antenna works with nearly 100% copy almost anywhere in my county and there's near zero reason I would think to replace it with something else. There are some rather isolated places in my home (i.e. directly behind a steel door) that I've been able to see the (Harris P25 simulcast) system drop out but the vast majority of the time and placement this thing works flawlessly. Wonder if this just varies based on the service your county / system is providing to you. Also I'm not looking to monitor the system from a significant distance i.e. a county over so maybe that helps too.
  #62 (permalink)
Old 07-11-2018, 12:24 AM
W8RMH's Avatar
Originally Posted by NC3Z View Post
Well with all this antenna testing I have somehow managed to kill the stock stubby antenna. I have done nothing more than remove and replace the stock numerous times. Now it get zero signal, but the other antennas I have been testing work just fine so I doubt it is the G4's connector.
I have already contacted Ray's pager and they are looking into it. But kind of weird.
Did you break the pin off on the stock antenna? Also aftermarket antennas vary, as their connectors may be longer, or shorter. You may have forced the radio's connection down to where the stock antenna pin no longer connects.
  #63 (permalink)
Old 07-11-2018, 6:03 AM
NC3Z's Avatar
I have looked at both under magnification. Both connectors look intact and as normal. On the antenna I can see the gold center contact.
The radio SMA looks normal. But it may have been possible the other antennas pushed the inside down?
If anyone can measure the distance from the top of the connector down to the teflon spacer. I took a dial caliper and measured right at 0.25"
Gary NC3Z
NC AHIMT COML
  #64 (permalink)
Old 07-11-2018, 6:10 AM
NC3Z's Avatar
Originally Posted by tp3244 View Post
I honestly find this thread to be weird/surprising. My stock G5 antenna works with nearly 100% copy almost anywhere in my county.
Thinking back to why I started testing other antennas, the stock antenna may have been bad from the start and just got worse. As I noted I had at least a 15dB improvement per the RSSI meter, that is a lot of difference.
Gary NC3Z
NC AHIMT COML
  #65 (permalink)
Old 07-11-2018, 6:29 AM
Signal-Zero's Avatar
My XTS and APX radios with their stubby antennas are all range and signal comparable with my G5 with its factory stubby. Iíd check the pin on the G5.
"We celebrate our independence from the Government, not our dependence on it."
  #66 (permalink)
Old 07-11-2018, 6:52 AM
NC3Z's Avatar
With a dial caliper I did measurement checks and the pin is at the proper depth. Ray's Pager is getting me another antenna, he said they have seen some issues with the stock antenna.
Gary NC3Z
NC AHIMT COML
  #67 (permalink)
Old 07-11-2018, 7:14 AM
troymail's Avatar
I agree that the stock stubby antenna generally works just fine (and is prefered if wearing the unit on your belt) within the area of coverage for most simulcast systems... but there are always exceptions.
I myself initially started trying other antennas (the RS 800, Moto, etc.) to "extend" my reception to systems outside my local area where I lived in Maryland. The Moto was a bit better than the stock stubby and the RS 800 did even better than the Moto. With the RS 800, I could receive systems from Harford County MD to Fairfax VA from inside my house.
When driving and monitoring a statewide system, I usually switch to the stubby. In that situation, you don't (most times) want a "better" antenna the causes the radio to stick to a distant site when you've passed others that are closer along the route.
Living here on the southeastern coast on North Carolina, I pretty much must use something better than the stock stubby to receive the two local NC VIPER (non-simulcast) sites which are only 7-8 miles from me.
Unication G5(UHF)
  #68 (permalink)
Old 07-17-2018, 7:05 AM
rvacs's Avatar
OK All
Got an antenna off Ebay - cheap Motorola type but it doesn't screw on deep enough to make contact. I will have to trim quite a bit of the base to get it to connect fully.
WHAT IS AN ANTENNA - That I DON'T HAVE to Trim for my G4 ?? Besides stock stubby.
  #69 (permalink)
Old 07-17-2018, 7:18 AM
I would say all cause none of them was invented for the g4/g5
Sent from my SM-N950U using Tapatalk
  #70 (permalink)
Old 07-17-2018, 7:32 AM
There are numerous threads regarding antenna selection for the G4/G5 series. But before you search and purchase let me just give my .02:
Most factory Motorola antennas will require you to trim the bottom in order to get a proper connection. Because of this, I have seen the pin forced down requiring a trip back to Unication to repair.
The Unication factory antenna is literally on par with my factory stubby antenna on my several thousand dollar APX portable. As a matter of fact, both radios will go out of range at the same time when I drive outside my Countyís coverage area.
The external antenna only applies to reception on the 7/800 band. On the G5, it has an internal loop antenna for VHF or UHF.
While the use of a longer antenna will increase reception distance (I prefer the RS800) if you are going that route, Iíve really found that it wasenít that great of a distance while mobile to really justify it. The same reason why I use a stubby on my APX vs the longer factory antenna. With 7/800, itís either there or itís not.
  #71 (permalink)
Old 07-17-2018, 8:50 AM
NC3Z's Avatar
I was a proponent of the longer antenna as I was seeing a 15dB improvement as I live in a very fringe area. But now that I had to send my 1 week old G4 to the factory as the antenna connector failed I will stick with the stock antenna from here on out.
Gary NC3Z
NC AHIMT COML
  #72 (permalink)
Old 07-17-2018, 9:54 AM
seth21w's Avatar
I have a moto antenna and the bnc adapter/rs800 and the motorola is the same range as the stock stub the rs800 is slightly better than stock, but not enough to tell much difference so i am just sticking with the stock stub, i chalk it up to me being used to scanners, and having to have many antennas! With this unication pager it is built to pick up clear even with just 1 signal bar. Just got to get used to not having to buy so many antennas to make it work. Because it just does!
Unication G4 Tytera MD390G RTL SDR *Sold SDS100*
  #73 (permalink)
Old 07-17-2018, 12:05 PM
rvacs's Avatar
Ok all..
Guess its just best I stay stock.
Thanks.
