G4/5 Amplified Charging Base No Sound
jmontes77029
Baytown, Tx
I just purchased a amplified charging base for my g4 and there is no sound coming from base speakers, only the g4 speakers. It charges my g4 but the is all. I noticed on some videos that there is a c next to signal strength bars when connected to base but mine does not show thevC when I attach to base. Anyone know what I may be doing wrong?
troymail
Silent Key
Aside from a possible defect, the only thing that comes to mind is to make sure the pager is seated well into the cradle...
Beyond that, take a look at the connections on the pager and in the cradle to see if anything looks odd.
AnikF1R
Minnesota
I often have to re-seat my G4 in the cradle after a first attempt. If I don't do this, the pager won't "recognize" the antenna that's plugged into the BNC jack on the back of the charger.
jmontes77029
Baytown, Tx
Problem solved. One of the connections on radio was dirty and had corrosion. I cleaned it up and bam it worked!
