Inside info
IAmSixNine
Dallas, TX
Its a public safety device targeting fire / ems users who use them as pagers or monitor one channel.
We are the side users who want what the pager was not meant for. At least not yet.
Hopefully Unication is looking at making us scanner users a targeted market.
Spitfire8520
I might be completely clueless! =)
Colorado
A vast majority of the users would have dedicated knob positions for individual channels much like an actual radio. This simplifies operation of the pager and doesn't require them to look at the screen and mess with buttons. Actual intended users would also likely be parked on their own dispatch and not scanning to minimize their chances of missing a call.
mharris
Columbus, OH
Wouldn't Fire Service users benefit from a scan hold as well?
I believe they would benefit for sure. I can't think of any radio with scanning capabilities that you can't stop the scanning, or hold. My Motorola radios all have scan which you can turn on and off. I'm sure it's the same with Harris, Relm, Kenwood, and Icom. They are all professional radios like the Unication.
boatbod
Talbot Co, MD
It really depends how you program the radio, and whether you set up one tgid per knob position or multiple.
For our county there really is no need for a scan hold. Once the dispatch takes place we know which tgid is going to be used for tac communications.
krokus
Southeastern Michigan
That is going to vary, but not for most FD users. Having priority scanning, and thoughtful selection of layout, your primary concern be the priority channel/TG.
Sent using Tapatalk
TFrank615
Springfield, Ohio
In my Departments case, this may help us. We are dispatched on 2 talkgroups, however only one of those two talkgroups transmits tones, and the other is for unit to dispatch traffic. What screws some things up is even when dispatch is answering a unit, theyre still talking over both talkgroups and not just the unit to dispatch channel.
krokus
Then one of two things would solve this.
1) Dispatch only talks on the dispatch TG when making the initial alert. All other comms are one the answer TG.
2) After being alerted, change the selector knob to the next position, which puts the answer TG as priority.
Sent using Tapatalk
TFrank615
Springfield, Ohio
Sent using Tapatalk
That’s 100% to complicated for the midage and older guys to comprehend. Was trying to make it easier and all on one channel. Which I’ve figured out, it’s not the 100% best but it’s been working decently so far
tglendye
Blue Ridge Mountains, Shenandoah River
Virginia
It looks like I’m getting a G5. I’m in public safety and would love the a Hold option as well as an Avoid or Lockout. Just trying to learn the ins and outs now before it arrives.
Yet no one has given an answer to what other feature is to be sacrificed, to convert a button to being a hold. (Assuming it is possible, with a firmware change.)
Sent using Tapatalk
Can you program the buttons? Maybe have different programmable functions for a short press/ long press.
krokus
No, the functions are set by the company. I am not sure if they are hard coded in the unit, or part of the firmware. Either way, they are not selectable at the consumer level.
Sent using Tapatalk
tglendye
Virginia
Sent using Tapatalk
Thanks for the reply.
mharris
Columbus, OH
I didn't think of user programmable buttons, via CPS. That's an excellent idea and would enable more functions to be added; some of which may not be used by everyone, but used by many (such as hold, avoid, nuisance delete, etc.).
