Unication Receive Types - Motorolla Type II Smartzone to P25
rvacs
Tulsa, OK
As we start seeing more and more movement from older systems (EDACS / Motorolla Type II Smartzone) to P25 Phase I or Phase II. I notice more and more agencies running them in parallel till the switch.
I look at Oklahoma
Tulsa - Motorola Type II Smartzone - also running OKWIN Phase I P25
Oklahoma City - EDACS & Smartzone II - also converting to OKWIN Phase I
QUESTION:
What systems does the Unication G4/G5 cover besides P25?
I assume no Smartzone II or EDACS
And if its P25 Phase I or II - yes...does it also listen to A (analog) - I know it does D (digital) and also know DE (Digital Encrypted) of course is encrypted listening to garble.
I have the G5 with VHF - so guessing it gets the APCO P25 VHF - Does it do the old Analog VHF?
PVPD730
I look at Oklahoma
QUESTION:
At the present time, the G4/G5 only covers P25 Phase 1 & 2 trunked systems and conventional P25 frequencies, no SmartNet, SmartZone, or EDACS. It's also DMR capable, however, it's my understanding that particular feature has yet to be released. The G5 will receive analog/conventional UHF or VHF depending on the model.
As far as the encryption goes, the G4/G5 will decode provided the device has been loaded with the proper key (AES only-it won't do ADP or DES).
rvacs
Tulsa, OK
This is what I figured...just wanted to verify.
Guess I am trying to understand P25 conventional - is there a system that you can used as an example that is using P25 conventional? I think Texas DPS is one...just trying to verify.
IAmSixNine
Dallas, TX
Correct Texas DPS is conventional Digital aka conventional P25. VHF
Balch Springs TX also uses conventional P25 800mhz
