That doesnt answer the question. Is it working properly for the most part or have a million issues?
I guess you cant read very well. I asked if it had a million issues. I did not say it had a million issues...dude.
Its all good though, So far two people say its fine but I'd like to hear from a few more users. preferably someone that uses it a lot and knows all its pros and cons or bugs whether big or small. Also, wondering can you set it to a static ip address as I have a block of them and would prefer to do that if possible.
Well, you're a bright one to jump on the dog pile rather than post something more helpful. Safety in numbers huh?I think it's more that you don't type very well.
If you set the scanner to access point mode it will always do that with 192.168.1.1
If you set it to infrastructure mode it will use DHCP to get an ip number and that depends of how you set up your router, if you only allow one ip from the pool or lock the MAC address of the scanner to a certain ip number, if your router can do that.
/Ubbe
