What do you mean when you say "it shows up as" a P2 TDMA frequency?ok here is a question I would like to know why is it on the home patrol 2 when you enter a P2 TXDMA FREQUENCY IT shows up as such but when you add one into the 536 and 436 it just shows in the software as a p25 plain system.
Ok. So we are not talking frequencies, but systems. Different question.Let me see if i can express this with out making it look like a book, in the software where you have your systems it shows weither its a p25 or conv.
With my 436 it will show lakeland fla as a p25 system but it is a phase 2 system. And when i add it to my home patrol 2 unit it will show up as a phase 2 txdma in the systems line in the software.
You may or may not be aware but there was something (mostly history now I think) called "X2 TDMA". It was "a thing" (from Motorola) before the P25 Phase 2 standard was agreed upon.Let me see if i can express this with out making it look like a book, in the software where you have your systems it shows weither its a p25 or conv.
I would agree with you on this. Some of the earliest P25 systems in my area were entered in the database as 'X2 TDMA' in the original HP-1 database.You may or may not be aware but there was something (mostly history now I think) called "X2 TDMA". It was "a thing" (from Motorola) before the P25 Phase 2 standard was agreed upon.
I just did an import of some Polk FL systems including Lakeland P25 into the Home Patrol (not x36) Sentinel...
It looks like when Uniden implemented Phase 2 in Sentinel, they coded it in the software/firmware that P25 Phase 2 systems as 'separate' from P25 Standard.
The reason for this might be that the initial P25 "Phase 2" capability that was released was a Motorola product before the true "standard" for P25 Phase 2 was agreed upon. This initial release for Motorola was called "X2 TDMA". I believe most system owners (Prince George Maryland being one of them) that implemented "X2 TDMA" were told by Motorola that once the official Phase 2 standard was available, they would be converted to the P25 Phase 2 standard and the "X2 TDMA" would be a thing of the past.
Even some of the newer systems here, including GMRS (Garland, mesquite, ...) that went live in the past few months, are listed in the HP-1/HP-2 Sentinel as X2 TDMA.It would appear this never changed in the Uniden Home Patrol code and every "Phase 2" system that is imported (based only on my quick test of Lakeland FL and Maryland FiRST) still gets set to "X2 TDMA".
Yep. The same systems that the HP-/2 Sentinel shows as X2 TDMA are in the x36HP series Sentinel as P25 standard.I believe that the 436/536 scanners were released after the P25 Phase 2 standard was on the street.
Actually, I'd already tried this, manually creating a duplicate system, but labeled as a P2 Standard, or P25 Phase II, and then compared reception with the listed X2 TDMA. I saw no difference in performance, regardless of which system name was used. That was also the result whether on the HP series scanners or the newer x36HP series.I'm really curious what would happen on the Home Patrol if the system actually has Phase 2 talkgroups but you program it into the radio as a "P25 Standard" system.....
So it really comes down to just the code interpreting the RR database and what that code does when loading and converting that data as a description of the system type between the x36 and home patrol Sentinel apps, since the actual radio firmware functionality appears to handle either interchangeably.Ah, that's what I was looking for. It seems like the Phase 2 systems are being incorrectly set to X2 on import but perhaps it was felt it didn't matter if, in the end, P25 Standard and X2 TDMA point to the same functionality/code in the Home Patrol firmware now and the system type doesn't matter (in the case of P25). I suspect there is enough known about how to parse the CC data to determine which is really is.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
