Love the echo on the first of the two videos you posted
I've noticed when scanning a single freq DMR, if you toggle the display mode option Func + 6,
the following will be displayed:
Mode 1: ID + Frequency
Mode 2: ID + Color Code
Mode 3: ID + Slot #
I can't seem to get the radio to display both Color Code and Slot # at the same time during a service or
custom search. I have toggle tone/code search to NAC/Color Code, which at least gives me the Color Code when it's on, and DMR type when it's off.
Up on the TWiki:
http://info.uniden.com/twiki/bin/view/UnidenMan4/DigitalMobileRadioUpgradeforBCDxxxP2
It says:
During a search, when the scanner stops on a DMR transmission, the following information will be displayed:
•DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), and the received color code.
•DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code.
Are you able to get the Color Code and Slot Number to display simultaneously?
