Can the dmr upgrade be added to the 436 after it is purchased?
It could be helpful if you have the code from the previous owner, in the event that a major repair involved replacement of the main system board. In that case, the key would need to be reentered.If we buy a used 436/536 that has the DMR upgrade, do we need to get any key numbers or codes from the prior owner, or will the used scanner receive further DMR updates with no further issues? What if we need to redo the upgrade?
Worth the money. There is so much DMR out there.
That depends -- where you are and if you care about what is using DMR....
I have nothing in my (current) home area....
Do you homework - don't waste the money if there is nothing of interest to listen to...
Same here, unless you like school bussues, transit busses and valet parking attendants.
Don't forget the hammies on the DMR MARC network and Brandmeister.
