SDS100 vs. BD346 - A picture is worth a thousand words
racin06
Westfield, Indiana
As you can see, the SDS100 is receiving full bars on the signal. The BCD436 receives at best one bar. The tower is approximately 25 miles away.
Both scanners are using the Remtronix 800MHz antenna and the same exact SMA to BNC adapter, as well. Perhaps, I can post some video in the near future.
RogueSteward
It's pretty amazing what software and program routines can do to reduce noise and discriminate the signal.
jonwienke
More Info Coming Soon!
VA
Signal bars are not particularly accurate or meaningful. A better metric is the number/duration of transmissions received by each radio when hooked to a common antenna. That said, given the conditions in the photo, the SDS100 is likely to pick up a lot more traffic than the 436.
klinquist
A photo I just took.. I have a fancy camera and a lightbox..
DSC45
Central Jersey
Hi! What is your assessment of the comparison clarity receiving the signal, and which system are they monitoring?
Thanks,
racin06
Westfield, Indiana
The system being monitored is the Project Hoosier SAFE-T system (P25 Phase I). The difference between the two scanners is very noticeable...the 436 picks up maybe 30 -40% of the radio traffic and probably 50% are broken and garbled. The SDS100 seems to pick up all radio traffic with very clear audio.
racin06
Westfield, Indiana
So, if signal bars are irrelevant, then why have signal bars? Uniden claims the SDS100 receives signals better from distant towers. I believe the photo confirms that claim.
DSC45
Central Jersey
That's some great information! Love to hear that, hope it works as well for me.
Thank you.
