plutonium233
- Joined
- Mar 31, 2008
- Messages
- 59
Hello,
I recently bought a BCD536HP, and so far I've been able to get Siren working on the home network. I would like to be able to listen to and control the scanner remotely; however, I am running into some issues with setting this up. Initially, I thought it would be as simple as port forwarding and using my dynamic DNS, but I quickly found out that this isn't feasible. I decided to try the VPN route so I followed some instructions online to configure a Windows 7 PC as a VPN server (PPTP). I was able to connect to it with my iPhone once I got it up and running, but I haven't been able to get the Siren app to connect. It seems like several people were able to get this working easily but it hasn't worked out for me so far. I am using the same IP (192.168.1.14) as before, but it refuses to connect.
The only thing I can guess is that maybe this VPN server isn't truly a VPN server in that it will allow me to access other devices on my network, but it will let me access printers, shares, etc on that particular machine. I don't know this for sure, but that is the only thing I can imagine. Does anyone have any suggestions on what I should try next? Note: I looked into using my router to setup the VPN server, but it doesn't have that capability and I can't readily upgrade it since it is an ADSL router that belongs to my ISP.
Thanks in advance!
Thanks in advance!
