Sentinel Software freq database
MourningRain
So.. I've played with my new BCD436HP scanner for about, maybe, a half hour so far.
I'm coming from a Radio Shack pro-34 scanner, so you'll probably see me here asking questions over the next few weeks+ :)
I installed the Sentinel software and plugged in my scanner with the mini-usb cable included in the box with the scanner. I updated the firmware and the usa/canada databases.
Two questions here...
1. I bought the "Uniden USB-1 Scanner Radio PC Interface Cable" for about $30, If a standard mini-usb cable works.. Is this something I can return? Pretty expensive short usb cable
2. By buying the BCD436HP scanner, I essentially have a premium subscription to the RR database? Since, with the sentinel software, it will always download updates to the database from here to my scanner?
ofd8001
Louisville, KY
Can't answer #1, check with the seller.
#2 - that's the theory. Uniden and RR have a "business relationship" where Uniden accesses the RR database weekly for updates. Users can then access the Uniden database to retrieve these updates. The cost of that Uniden/RR "relationship" is factored in the scanner price.
MourningRain
not really can I, but more like "should I"
For #1, I know I 'can' return it (to Amazon in this case), but I am wondering is the cable, which I guess apparently has a chip in it to emulate a com-port? is needed for some app besides sentinel?
Thanks for the reply :)
#2 is a good deal!
MourningRain
Answering my own question
Apparently the special cable is only needed for *XT and some other models.
part# BWZG1666001 is the suggested cable for the bcd436hp, which seems to me to simply be an expensive regular mini usb cable with the addition of a ferrite core on the end.
Guess I'll send it my usb-1 cable back
ofd8001
Louisville, KY
There was a period of time, back in the x996 scanner days, the programming cable supplied by Uniden had the RS232/DB9 end. Unfortunately few people still had computers with serial ports to connect that RS232/DB9 plug into their computers.
So some creativity went to work and Uniden devised that USB-1 cable. It has a chipset in it which makes a USB Port act like a serial port.
From Home Patrol 1 on, Uniden used a different programming cable, one that is USB friendly. I'm sure that USB friendly cable came with your scanner. Unless you have a "pre-Home Patrol" scanner, that USB-1 cable won't do much for you.
danzan77
Findlay Ohio
Anyone know if theres something better than sentinel software that works with bcd536 and bcd436. I can't figure out how to remove mi Ontario etc. Basically just ohio until I go somewhere out of state. It wont let me delete or move anything. I like the concept of win500 for whistled scanners.
Sent from my SPH-L710 using Tapatalk
ofd8001
Louisville, KY
Are you scanning the full database? If so, try reducing your Range value.
If you are using a Favorites List, just edit the Favorites List, click the cell with the name of the system you want to remove to highlight it, then click the red X to delete.
ARC/Butel has software for the Sentinel and I believe Proscan will also work. However, I can't see them being any easier than Sentinel to remove a System (or parts of a System) from a Favorites List.
