BCD436HP/BCD536HP: How do I get out of search mode?
duke94
Ann Arbor, MI
I guess I pushed too many buttons! I have the scanner stuck in "search" mode so it searches thru a upper and lower frequency range. I'm trying to just get back to Scan mode to listen to the local P25 system. I somehow did this trying to download a favorite list using Sentinel.
hiegtx
Mentor
Dallas, TX
Check your profile in Sentinel. You may have inadvertently turned on one or more pre-programmed searches.
You can lockout (Avoid) the search by hitting <Function>+<Avoid>. But if you turned it on by accident in Sentinel, you'll be back in the same rut the next time you upload an updated Favorites list to the scanner. So, make sure they are not set to run.
duke94
Ann Arbor, MI
Push the function button on the side (the top one) while pushing the System button on the front. (left white key.
Thanks, I've read through the Manual a number of times and there's still a LOT of these tricks I miss. I think a Glossary in the back would have been helpful.
duke94
Ann Arbor, MI
I'll check that. I don't think I've grasped the basics of Sentinel yet. Will keep trying.
dcisive
Salt Lake City, Utah
I can relate. That happened to me the first night I programmed my 436 and also finally read up you needed to push the Function then System. I no longer have to think about it fortunately ;-)
duke94
Ann Arbor, MI
I still can't make my favorite list work. I did a small one in Sentenil and down loaded it to the scanner. It's in the scanner, but the quick key doesn't work.
LisaNels
Boise, Idaho
I just got my BCD536HP yesterday, so I'm having a fun time with it. But I did notice that when I'm doing a search it says on the bottom of the screen <F+SYS to SCAN>
The function button being the big knob on the left. Press it in once, then press SYSTEM and it's back to scanning the fav lists.
