Just ordered the 536 hp hope I can program this scanner by zip code!!! Just like my home patrol one..
The 536HP can be programmed via zip code, the same as your Home Patrol. In fact, if you want to program it the same as the HP, you can do that easily. In your Home Patrol, export your Favorites list (if you have one) to an *.hpe file using the HP's version of Sentinel. Note where the file is being saved..
Then, start the 536HP's version of Sentinel, and import that 8.hpe file. Then, using Sentinel (for the 536), you can edit that list to enable the alert led colors, quick keys (if you want to use them) and any other changes you want.
