Programmed with Sentinel....set up FL's on Sentinel and wrote to scanner
Most of the talkgroups for given systems will be listed in the database. However, in "ID Search" mode, you will see TGIDs that are not listed in the database or were omitted/removed from a given system in your programming.
You
may also see what are known as "private call" identifiers I believe. These are no "talkgroups" but rather individual radios (IDs) talking directly to one another.
Which system? Can you provide a couple of talkgroup IDs you are seeing for that systems that are not identified?
