LCN Finder for the x36hp
AC0RV
Park Hills, MO
Ok Where can find the LCNs after the finder gets through searching.
Also where can I find more info LCN finder.
Big thanks.
buddrousa
David after you do Function System it will ask to save say yes then go to menu then Manage Favorites then choose the system you want to see then review / edit then pick the system then site edit then pick the site then go through each frequency then LCN is after you enter the frequency.
In PROSCAN open a NXDN site all the Frequency Info is Listed
garys
That sure seems pretty complicated. Not that I doubt you, but there is nothing intuitive about that at all. I'm running Analyze on an LTR system and couldn't figure out how to find the results.
jonwienke
More Info Coming Soon!
VA
Or you could read from scanner in ProScan or Sentinel.
