Unless I'm missing something the Sentinel Software for programming the SDS100 doesn't have the Ohio MARCS-IP Statewide trunked system in the database, it only has the old deprecated Ohio MARCS system in there.
I just downloaded Sentinel version 2.00.02 yesterday and made the assumption that the database would be up to date. I did an update to the database and it's there now, thanks for the help, still a little bit new to the world of Sentinel.
I downloaded Ohio Marc’s for Ashtabula county from Sentinel for my SDS100. I can not get it to just scan the county and not the entire state! I set talk groups and Ashtabula county Marc’s setting. When I down load to scanner it scan the state any ideas?
Agreed.
You should have at least 3 tower sites
Geneva
Ashtabula
Lake Erie C.I.(Conneaut)
The rest you can “set avoid”.
But MARCS-IP you can pick up so many other counties why only scan the one ?
I'll guarantee it IS there.
OSP is not under the county but under Statewide Systems and then
Ohio MARCS-IP: Multi-Agency Radio Communications
then by OSP District (number)
