Can someone please check to see if Sentinel shows PA/Dauphin/County and see if the Dauphin County Prison DMR shows on the list. For some reason it does not appear for me to select to add to my faves
It does not. It may be because it's not listed under any subcatagory?
I've added it to a subcatagory at the top, when the database gets refreshed monday, check back and see if it's there.
It does not.
It's likely because it has no known talkgroups. That's normal.
That mischaracterizes what I said. The main dB has no provision for ID Search. We only put things in the main dB that are scannable. Otherwise, the scanner would waste a bunch of time scanning systems that have nothing to actually scan and generate an entirely other set of complaints. I'm going to stick with the complaints I have.
Dauphin County Prison did not appear in the DB update I did in Sentinel. It did appear in ARC536
See post #2 - same answer.
So I would have to use ARC as well so I could add a system with no TG listed just so I can try to identify if TG do exist...that is a PITA.
So I was able to get the system on the sds via ARC. There are no TGs on the system yet (only one site). Even if I turn on ID search for the system, I can not use the QK to activate scanning. For example, all of my other QK work great (FQK. SQK) activates/deactivates everything else just fine. The system with no TGs just gives me error beeps when I try to use the QK (in this case 0.12E
Another issue caused by same as above?
TIA
Sent from my SM-G965U1 using Tapatalk
Not sure - but just enter a dummy talkgroup.
What error?
