Share your SDS100 Display Customizing Settings
mrlindstrom
Klein, TX
Since we can now import/export the custom display settings within Sentinel, anyone willing to share their XML files?
WX4JCW
Stow, Ohio
It will be the whole profile I think
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
SteveSimpkin
Lancaster, CA
Jason WX4JCW
No, it exports to an XML file that appears to just contain the display settings and nothing else. See the attached example file (renamed to .TXT extension for compatibility with this site).
  • SDS100 Display Settings Example.txt
jonwienke
More Info Coming Soon!
VA
2 questions:
Where is the XML file saved when you click the Save button?
Without a Load button, how do you import display settings?
SteveSimpkin
Lancaster, CA
2 questions:
The new Display Customizing Settings Import/Export feature is located under the File menu in Sentiel. See attached picture.
From there you can Import or Export the settings to an XML file. You can also choose the file location.
WX4JCW
Stow, Ohio
Perfect
Jason WX4JCW
jonwienke
VA
Here's mine. There is a typo in the main XML tag:
UndienScanner Model="SDS100"
  • jonwienke.txt
mrlindstrom
Klein, TX
Just rename the .txt extension to .xml (or change it to xml in the save dialog when you click it to download).
trido
Retired
Southern In
thanks i was making this to hard.
so simple thanks hope other will share
here is mine
  • trido.txt
WX4JCW
Stow, Ohio
A screenshot would be nice too
Jason WX4JCW
nessnet
Eastside of Lake WA
A slight variation
I moved the voltage to the top and the noise/dig error to the bottom, by the RSSI.
  • ness1.txt
WX4JCW
Stow, Ohio
Here is one i am working on, a little different than Johns
  • wx4jcw_display.txt
teknishun
Alvin, Texas
Share your SDS100 Display Custom Settings
<lol> Undien or Uniden?
You don't suppose that is done deliberately by Uniden as
a "booby trap" code to catch possible copyright infringements for those who would
use Uniden's proprietary information illegally?
Nah.
