It's the nature of the beast. My GRE or Whistler models take even longer to display the drive letter when I plug them into my computer. The OS seems to make no difference to me and they are all slow! I've tested on computers without AV software but same lag. It's not quite 90 seconds here and is more like 35 seconds for a GRE design while the Unidens are slightly faster at maybe 25 seconds before ready in mass storage mode. Still slower than a flash drive mount time as Hit_Factor mentioned.
When I plug in a Uniden and select Serial Mode, the serial mode driver loads within maybe 5 to 10 seconds tops and the serial port is ready for communicating with control or monitoring software. So it's the Mass Storage Mode that takes the long time before the radio is displayed as a hard drive on the computer. This mode does NOT use a 3rd party driver. It uses the same built in driver that has been used in Windows darn near since USB support was added back in the Win95 OR2 release or whatever they called it. B or OR2 rings a bell when USB support was added to Windows OS.
USB flash or thumb drives take about 10 seconds here before they mount and show up as a drive letter after I insert one into any USB port, USB 2 or 3.
I'd say the extra time needed for the scanners is probably a limitation of the scanner. It's probably something in the scanner that takes time before it can negotiate with the computer is my guess.
GRE designs are also painfully slow at updating or writing your data back to the radio. Reading is also slow but not as bad as writing! The GRE designs really seem to compare with USB 1.0 or .1 speed specifications. I've always suspected there is something in the GRE USB hardware that limits it to USB 1.1 speeds. Even my newer TRX models are just as slow as any older model. For the GRE radios, you can really see the difference if you mount the SD card in a card USB 2.0 or 3.0 card reader. When your SD card is inserted into a card reader, the software will update the DB or your profile on the card lightning fast when compared with doing it with the SD card in the radio attached to your computer! Even when a card reader is attached to a USB 1.1 port, it is still faster than when doing it with the card still in the radio.
I personally still find removing and placing the SD card into a card reader to be more of a hassle then the slowness you see when in the radio so I still do most of my SD card changes while the SD card is in the radio.
Gives me time to grab a coffee or brew as K9DAK said!
