Copy the sentinel folders to a shared drive. Then under tools and options change the folder location on both computers to that shared dive sentinel folder. The what ever changes you make on one computer will show up on the other computer.
I created a shared folder environment like papa is suggesting yesterday, and it seems that this is the best option if you have such a network folder to use. However, from the troubles I had I think you want to change the
order of things:
First : In both Sentinel programs change the Sentinel folder location to the desired new Sentinel folder on the shared drive and exit Sentinel on both computers.
Then: Copy/paste the original Sentinel folder contents into the new shared Sentinel folder.
The reason is that (as I learned the hard way) when you change the folder path in Sentinel it immediately writes a fresh, empty set of folders (no favorites, etc) to that new folder overwriting what ever might already be there. If you had profiles/favorites there they will be gone. So you need to copy your originals there
after changing paths.
Actually, I would recommend starting by backing up your existing Sentinel folder to some other location before you do any of this as a backup in case things go wrong. What could go wrong? Oh I don't know, perhaps for whatever reason changing the path back to the original then back again to the shared folder. It will trash your original files in both locations. You would have to be dumb (ahem, clears throat, averts eyes ) to do something like, but it could happen. Someone also pointed out that you can use your scanner as your backup and "Read from Scanner" to populate new Sentinel folder.
If I am wrong about any of this (but how could I be with my whole 1.5 days of newbie experience?
) then someone please correct me.
Don
