SDS100/SDS200: One Frequency DMR
b52hbuff
I have a question about how to program a DMR One Frequency System using Sentinel on my SDS100. I typically like to learn by doing or observing. From what I have read, Sentinel doesn't read in these systems in the most efficient way possible for the SDS100. So I want to program one system on my own, so I can verify the best way to do it.
I have been monitoring a new system for the Lehigh Cement Company. Here is a link to the license:
https://www.radioreference.com/apps/db/?fccCallsign=WQVS579
I have been monitoring/recording the frequencies in Digital Code Search mode. The channel indicator shows "DMR". I have figured out:
464.8125 / Color Code 14
TGID 4560 / Slot 1: Channel 1
TGID 4561 / Slot 2: Channel 2
461.05 / Color Code 9
TGID 4564 / Slot 1: Unknown 1
TGID 4568 / Slot 2: Unknown 2
Now the question… When I program this as a DMR One Frequency trunked system, how do I program the frequencies? Do I program them as one site with two frequencies?
Site 1:
464.8125
461.0500
Or do I program them as two sites, each having one frequency.
Site 1:
464.8125
Site 2:
461.0500
I think the best/recommended way is to use a Single Site with multiple frequencies per site, but I want to make sure. I would think that if One Frequency DMR could/should only accept one frequency per site, then this would be restricted in the site frequency form/input. But it isn't... So is this by design, or is this a bug?
jasonhouk
Marion, Ohio
Site 1:
464.8125
461.0500
Site 1:
464.8125
Site 2:
461.0500
Site should be thought of as, location of transmitter. Therefore I'd program both frequencies into one site.
Houk
Sent from my Moto G (4) using Tapatalk
Drkatzjr45
Emeritus Member
Hollister MO
This is something that I do not quite understand myself as well.
It is the “one frequency “aspect that I do not understand
For example, a business that I want to follow uses a DMR and has six frequencies.
With the Whistler scanner it allows you to program all frequencies in DMR mode, which I might add, DMR comes with the scanner… You don’t have to pay extra for it
If someone would be kind enough to explain how this works I would really appreciate it
ProScan
Software Provider
Ontario, Calif.
DMR One Frequency system is the Uniden way of using(ID Scan and logging) TGID's and UID's on a conventional system. If those six frequencies are part of a trunk system then set the system type to MotoTRBO. If those six frequencies are conventional then put all six frequencies in a DMR One Freq. system.
SteveSimpkin
Lancaster, CA
As to why Uniden charges for DMR and Whistler does not, part of it is because of Uniden's business model and part is because they pay Motorola for use of their DMR Essential patents while Whistler does not.
DMR Essentials Licensing Program - Motorola Solutions USA - Motorola Solutions
https://www.motorolasolutions.com/c...rview/technology-leadership/dmr_licensees.pdf
Here is one of the many discussions on this topic:
https://forums.radioreference.com/t...g-for-dmr-provoice.351678/page-2#post-2895067
Drkatzjr45
Emeritus Member
Hollister MO
No, it is simply “up-selling” I think that is untenable.
And I understand.
They are in this to make a profit, and there’s nothing wrong with that
I find that this unit to be one of Uniden’s very best
I can tell it is made with quality, especially with respect afforded to the unit structure itself, and, the sound quality
And that’s what people really want:
quality.
They will pay anything for -quality-
